bgambino Posted September 27, 2009 Share Posted September 27, 2009 a 93 or similar Legacy? assuming this is indeed my problem Looks like I would have to remove the castle nut holding the tie rod and the nut holding the ball joint For the ball joint I usually smack the control arm(?) adjacent to the ball joint while hoding a little downward pressure on it. I guess the same for the tie rod Now what about those two bolts attatched to the lower part of strut?? I remember reading that one comes off and the other you need to mark with a punch?...then only loosen it so as not to lose alignment. Looking at it...it sure looks like the two bolts need to come out I am clueless as to how the bolt affects alignment and why both don't have to come out to get the hub off How much is one of these bearings? OEM and aftermarket? Is there one in there or two like the loyale/GL's I guess I would have to take it to a machine shop...any idea what that usually costs? R&R Quote Link to comment Share on other sites More sharing options...
bgambino Posted September 27, 2009 Author Share Posted September 27, 2009 here is the pic Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 28, 2009 Share Posted September 28, 2009 You got some nice rust goin' on there. Soak everything with PB for a day or so before you start tearing it apart. Mostly that affects wheel camber. You'll want to clean that whole area well. Mark the position of both bolts as well as the position of the strut relative to the knuckle. You'll have to line that back up as close as possible on re assembly or the camber will be off and the tire will start wearing unevenly. It will have to be taken to a shop to have the old bearing pressed out and the new bearing pressed in. Call a few places and ask for quotes. It changes depending on labor rates and how long the shop wants to charge you for. Some even stick people with "equipment" charges. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted September 28, 2009 Share Posted September 28, 2009 if you have decent sources it's often easier (and cheaper) to just replace the entire hub assembly used that has bearings already in it. guy in texas has a front set of hubs for 1st gen legacy for sale very reasonably in the for sale section. i would have bought them except they're for a non-ABS vehicle. Quote Link to comment Share on other sites More sharing options...
logic23 Posted September 28, 2009 Share Posted September 28, 2009 I agree with grossgary: replace the hub if you have the choice. Its usually cheaper and faster. I've run into problems with the machine shop not pressing the bearing right. The hubs assembly at our local yards are 30-50. The bearings are like 90 the last time I checked plus the machine shop cost. Quote Link to comment Share on other sites More sharing options...
tcspeer Posted September 28, 2009 Share Posted September 28, 2009 (edited) I agree replace the hub, the top bolt on the strut is the one that needs marking on my 97 Legacy, the reason it is not round as it is turned it will move things around. Mark both and then when you get them out you will see the one that is important. Once you replace the hub with one from junk yard you have the option of getting a cheap press from Harbor Freight then you can practice all you want with the old one. Once you get it cleaned and apart and replace the bearing and seals, and regreased you will be able to take it apart and put it back together without things being destoryed. You would not want to put this one back on your car without replacing the bearing and seals again, it would only be good to practice with. Edited September 28, 2009 by tcspeer Quote Link to comment Share on other sites More sharing options...
unibrook Posted September 28, 2009 Share Posted September 28, 2009 Hub Tamer is useful as an option. You can leave the hub and knuckle on the car with this tool. Not cheap however. Quote Link to comment Share on other sites More sharing options...
CNY_Dave Posted September 28, 2009 Share Posted September 28, 2009 a 93 or similar Legacy? assuming this is indeed my problem Looks like I would have to remove the castle nut holding the tie rod and the nut holding the ball joint For the ball joint I usually smack the control arm(?) adjacent to the ball joint while hoding a little downward pressure on it. I guess the same for the tie rod Now what about those two bolts attatched to the lower part of strut?? I remember reading that one comes off and the other you need to mark with a punch?...then only loosen it so as not to lose alignment. Looking at it...it sure looks like the two bolts need to come out I am clueless as to how the bolt affects alignment and why both don't have to come out to get the hub off How much is one of these bearings? OEM and aftermarket? Is there one in there or two like the loyale/GL's I guess I would have to take it to a machine shop...any idea what that usually costs? R&R Whereabouts in NY? NYC? Dave Quote Link to comment Share on other sites More sharing options...
bgambino Posted October 1, 2009 Author Share Posted October 1, 2009 Whereabouts in NY? NYC? Dave Dave Are you in Cortland...Putnam county? I am in Dutchess Quote Link to comment Share on other sites More sharing options...
CNY_Dave Posted October 1, 2009 Share Posted October 1, 2009 Dave Are you in Cortland...Putnam county? I am in Dutchess near Cortland, but further North and West- out near Ithaca. A bit south of Syracuse. I *used* to live near Hopewell Junction, but of course that doesn't help. I'm not shy about helping folks with some presswork, but there's not a lot of folks around here. Dave Quote Link to comment Share on other sites More sharing options...
bgambino Posted October 2, 2009 Author Share Posted October 2, 2009 near Cortland, but further North and West- out near Ithaca. A bit south of Syracuse. I *used* to live near Hopewell Junction, but of course that doesn't help. I'm not shy about helping folks with some presswork, but there's not a lot of folks around here. Dave dave Wish you didnt move...you would have been 5 mins from me...i'm in stormville over near the prison Quote Link to comment Share on other sites More sharing options...
CNY_Dave Posted October 2, 2009 Share Posted October 2, 2009 dave Wish you didnt move...you would have been 5 mins from me...i'm in stormville over near the prison I remember dirtbike riding on the RR tracks behind the prison, riding all the way out to connecticut once or twice! And midnight headlightless full-moon winter dirtbike rides up over Depot Hill rd, and playing rally-driver up there. Ahhh, good times. Dave Quote Link to comment Share on other sites More sharing options...
