EastCoastEJ22T Posted December 5, 2009 Share Posted December 5, 2009 So i need to pick up a pair of oil pans, one for the 95 "L" 2.2 and the other for a 98 "GT" 2.5. I can pick up a new H6 oil pan from a friend for dirt cheap. But i think it won't fit? My question is are all the EJ pan's the same? Or do i need to order a specific pan for the 2.2 and 2.5? Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted December 5, 2009 Share Posted December 5, 2009 So i need to pick up a pair of oil pans, one for the 95 "L" 2.2 and the other for a 98 "GT" 2.5. I can pick up a new H6 oil pan from a friend for dirt cheap. But i think it won't fit? My question is are all the EJ pan's the same? Or do i need to order a specific pan for the 2.2 and 2.5? the 2.5L pan is larger, but i here it is interchangeable with the 2.2L pan. i would not use the smaller pan on the 2.5, less oil, but using the larger one on the 2.2 is probably ok. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 5, 2009 Share Posted December 5, 2009 So i need to pick up a pair of oil pans, one for the 95 "L" 2.2 and the other for a 98 "GT" 2.5. I can pick up a new H6 oil pan from a friend for dirt cheap. But i think it won't fit? My question is are all the EJ pan's the same? Or do i need to order a specific pan for the 2.2 and 2.5? Man - you need two oil pans? What are you doing up there!?!? I have an H6 and the oil pan certainly looks a good bit different. I'd be interested in buying that H6 oil pan if you don't use it, let me know. EJ oil pans shouldn't be too hard to find, some folks on here have blown engines - davebugs does, maybe he'll sell you one or two? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 5, 2009 Share Posted December 5, 2009 Man - you need two oil pans? What are you doing up there!?!? Probably rusting them out from the salt. GD Quote Link to comment Share on other sites More sharing options...
EastCoastEJ22T Posted December 5, 2009 Author Share Posted December 5, 2009 Probably rusting them out from the salt. GD correct!! we use more salt then common sense when it comes to roads up here. We have 10cm of snow on its way tonight......salt trucks will spreading by dark. Quote Link to comment Share on other sites More sharing options...
subaru360 Posted December 5, 2009 Share Posted December 5, 2009 Any EJ oil pan fits any EJ engine. As long as you keep the right pickup and baffle with the pan. Quote Link to comment Share on other sites More sharing options...
