SubaruJawn Posted July 23, 2010 Author Share Posted July 23, 2010 (edited) I have a driving the outback problem. I'm only 5'3" and i have to really stretch my leg to make sure that clutch pedal is all the way to the floor. i cant move my seat up because of my FAT gut rubbing on the steering wheel. the pedal is way to soft is there a way to harden the pedal ? And when i go to start it the key buzzes i have to let go and turn it again for it to start. is that Normal ? Edited July 23, 2010 by SubaruJawn spelling corrections Quote Link to comment Share on other sites More sharing options...
987687 Posted July 23, 2010 Share Posted July 23, 2010 I have a driving the outback problem.I'm only 5'3" and i have to really stretch my leg to make sure that clutch pedal is all the way to the floor. i cant move my seat up because of my FAT gut rubbing on the steering wheel. the pedal is way to soft is there a way to harden the pedal ? And when i go to start it the key buzzes i have to let go and turn it again for it to start. is that Normal ? The buzzing could be the starter relay. If you aren't pushing the pedal far down enough the relay may be opening and closing really fast if the clutch switch is just barely being pushed. Quote Link to comment Share on other sites More sharing options...
SubaruJawn Posted July 23, 2010 Author Share Posted July 23, 2010 The buzzing could be the starter relay. If you aren't pushing the pedal far down enough the relay may be opening and closing really fast if the clutch switch is just barely being pushed. its all the way to the floor. i just have to let the key go and turn it again the 2nd time. then it'll start Quote Link to comment Share on other sites More sharing options...
987687 Posted July 23, 2010 Share Posted July 23, 2010 Does it sound like a relay clicking on and off really fast? Quote Link to comment Share on other sites More sharing options...
SubaruJawn Posted July 23, 2010 Author Share Posted July 23, 2010 Does it sound like a relay clicking on and off really fast? i cant tell you. because i have no idea what it would sound like. all i know its a buzz not a click sound. I'll see if i can record it when i get a chance Quote Link to comment Share on other sites More sharing options...
SubaruJawn Posted July 25, 2010 Author Share Posted July 25, 2010 Lucky Me ! i have another I.A.C.V ! and didn't know it was going threw my parts and there it sat i believe its from the 95 Auto Legacy (the white Sedan) but its from a 2.2L does that make a difference ? Also had some fun in the outback.:cool: Quote Link to comment Share on other sites More sharing options...
AWDfreak Posted July 25, 2010 Share Posted July 25, 2010 OMFG.... How the hell do you have mud? There hasn't been rain here in forever, so I am extremely jealous. Do you have any off-road parks nearby? You should go to one to get some funny reactions from the truck crowd Quote Link to comment Share on other sites More sharing options...
SubaruJawn Posted July 27, 2010 Author Share Posted July 27, 2010 (edited) Scrounged up some change to get a can of carb and choke cleaner. $3 a can cleaned the PCV and IAC. no more Rough Idle and car doesn't vibe near as bad still does but that's normal engine running vibe... I'm sure well i'll report back if the rough idle comes back. Scratch that. Still Does it! Edited July 27, 2010 by SubaruJawn update Quote Link to comment Share on other sites More sharing options...
SubaruJawn Posted July 31, 2010 Author Share Posted July 31, 2010 Update: Put new rear Brake Pads on the Rear. and i now has Grille $53 Total at Patterson Auto Wrecking Quote Link to comment Share on other sites More sharing options...
SubaruJawn Posted August 1, 2010 Author Share Posted August 1, 2010 (edited) ok tried the Screw between the blue connection. The Speed-o is working again but will it keep working we shall find out soon enough Video: http://www.youtube.com/watch?v=Rq1oZZuk2IY Update: Took a short drive about 10 miles. the speed-o did stop working for a few seconds then worked again. now that i have gone the routine route it has been working. Edited August 2, 2010 by SubaruJawn Quote Link to comment Share on other sites More sharing options...
SubaruJawn Posted August 2, 2010 Author Share Posted August 2, 2010 Nope did not Fix it. still works at times. Quote Link to comment Share on other sites More sharing options...
mdjdc Posted August 2, 2010 Share Posted August 2, 2010 You actually have to dissassemble the head unit and find the cracked solder joint. Resolder it and you should be good to go. Quote Link to comment Share on other sites More sharing options...
SubaruJawn Posted August 2, 2010 Author Share Posted August 2, 2010 You actually have to disassemble the head unit and find the cracked solder joint. Re-solder it and you should be good to go. ok didn't hear of this one. wish i had a spare to take apart so i don't screw up this one. Quote Link to comment Share on other sites More sharing options...
987687 Posted August 4, 2010 Share Posted August 4, 2010 ok didn't hear of this one. wish i had a spare to take apart so i don't screw up this one. They're surprisingly simple to take apart. Just be careful and you won't break it. Quote Link to comment Share on other sites More sharing options...
SubaruJawn Posted August 6, 2010 Author Share Posted August 6, 2010 My Outback now has a Parts Car. 1998 Legacy would the gauges work in my 99 outback ? Quote Link to comment Share on other sites More sharing options...
SubaruJawn Posted August 8, 2010 Author Share Posted August 8, 2010 hmm. my outback has hydrolic clutch and the legacy does not. could i use the cable clutch in my hydrolic clutch outback ? Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted August 8, 2010 Share Posted August 8, 2010 hmm. my outback has hydrolic clutch and the legacy does not. could i use the cable clutch in my hydrolic clutch outback ? yes but you don't have to. it is easier to switch the other way. once you get the trans on the floor side by side you will see what you have to do. it's not hard. Quote Link to comment Share on other sites More sharing options...
SubaruJawn Posted August 8, 2010 Author Share Posted August 8, 2010 yes but you don't have to. it is easier to switch the other way. once you get the trans on the floor side by side you will see what you have to do. it's not hard. ok. my outback doesn't need it. i thought about keeping it for a back up trans. good to know. and thanks for the info Quote Link to comment Share on other sites More sharing options...
logic23 Posted August 9, 2010 Share Posted August 9, 2010 98 spedo won't work. 99 spedo= 1 year only part Quote Link to comment Share on other sites More sharing options...
SubaruJawn Posted August 14, 2010 Author Share Posted August 14, 2010 Hi Guys i would like to make my outback non-hydro clutch making my outback Cable clutch instead. i really don't like the hydro clutch its way to easy to press. i gotta put pressure on it and i rearranged the decals on the hatch. moved outback to the left and moved the awd up with out putting the legacy Decal back on. Reason: to look like the 2000 Outback :cool: Added 16 Valve Decals from a Pontiac Grand Damn . Quote Link to comment Share on other sites More sharing options...
987687 Posted August 14, 2010 Share Posted August 14, 2010 Another thing to note about the legacy transmission. It will most likely have a 3.9 front diff whereas your outback almost certainly has a 4.11. So if you want to swap them you have to change the rear diff as well. Also the legacy tranny has a longer 5th gear than the outback. Quote Link to comment Share on other sites More sharing options...
SubaruJawn Posted August 14, 2010 Author Share Posted August 14, 2010 Another thing to note about the legacy transmission. It will most likely have a 3.9 front diff whereas your outback almost certainly has a 4.11. So if you want to swap them you have to change the rear diff as well. Also the legacy tranny has a longer 5th gear than the outback. i never looked at that. my outback i have no idea what it has. the rear diff sticker is gone. my 91 legacy had a 4.11 Ratio so wouldn't a 98 be also ? i like 3.90 Gear ratio better BTW. and i dunno what would be best for winter 3.90 or 4.11 ? thanks for reminding me man. Quote Link to comment Share on other sites More sharing options...
987687 Posted August 15, 2010 Share Posted August 15, 2010 In the winter I'd prefer the 4.11 because trying to go slow in snow, getting un-stuck, etc. But 3.9 is gonna be better for the highway. I prefer the longer 5th in the legacy tranny though. I'm not completely sure that the 98 is a 3.9, but my 96 is. They had a few different setups, easiest to just check the sticker. Your OB DOES have 4.11 though. Quote Link to comment Share on other sites More sharing options...
SubaruJawn Posted August 15, 2010 Author Share Posted August 15, 2010 In the winter I'd prefer the 4.11 because trying to go slow in snow, getting un-stuck, etc. But 3.9 is gonna be better for the highway. I prefer the longer 5th in the legacy tranny though. I'm not completely sure that the 98 is a 3.9, but my 96 is. They had a few different setups, easiest to just check the sticker.Your OB DOES have 4.11 though. my 91 legacy with 4.11 did awesome in the Snow. i figured the outback had 4.11 because it takes off easy like the 91 legacy does. I'll check tomorrow if i don't forget. I'll be sure to report back and if i get pictures i'll post them. -John Quote Link to comment Share on other sites More sharing options...
SubaruJawn Posted August 16, 2010 Author Share Posted August 16, 2010 987687 is your legacy automatic or standard ? ok i checked and no Sticker ! so i have no idea what the legacy has ?! any other way to tell ? Quote Link to comment Share on other sites More sharing options...
