TheSubaruJunkie Posted August 25, 2010 Share Posted August 25, 2010 So I have Jibs down here, we're putting a EA82 5spd into his Hatchback. We have jerry's kit, we finally got the 5spd mated to the EA81, but we cannot get the clutch to disengage. It was a pain in the rump roast just getting it bolted together... took us 5 tries and finally we have the two together. However, when we press the clutch pedal the clutch fork moves maybe 1/2" at most and it does not disengage the clutch. The parts we used are. EA81 flywheel EA81 pressure plate EA82 clutch disc EA82 throwout bearing D/R EA82 5 speed. Can anyone help, give us some insight? Quote Link to comment Share on other sites More sharing options...
Turbone Posted August 25, 2010 Share Posted August 25, 2010 Did you install the clutch disc correctly? I think the long shank goes towards the trans. Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted August 25, 2010 Author Share Posted August 25, 2010 I checked with the FSM & the directions that came with the disc, and we installed the disc with the flush face, towards the engine... and the side with the springs exposed facing the pressure plate. Quote Link to comment Share on other sites More sharing options...
capn_r Posted August 25, 2010 Share Posted August 25, 2010 So I have Jibs down here, we're putting a EA82 5spd into his Hatchback. We have jerry's kit, we finally got the 5spd mated to the EA81, but we cannot get the clutch to disengage. It was a pain in the rump roast just getting it bolted together... took us 5 tries and finally we have the two together. However, when we press the clutch pedal the clutch fork moves maybe 1/2" at most and it does not disengage the clutch. The parts we used are. EA81 flywheel EA81 pressure plate EA82 clutch disc EA82 throwout bearing D/R EA82 5 speed. Can anyone help, give us some insight? Is there possibly some conflict with the EA81 pressure plate and the EA82 release bearing? When I did my swap I used a complete XT6 clutch kit and machined an EA81 flywheel to the XT6 step dimension and it has always worked fine for me. Quote Link to comment Share on other sites More sharing options...
bratman18 Posted August 25, 2010 Share Posted August 25, 2010 When I put an EA81 into my EA82 with 5 spd dual range I used all the EA82 clutch stuff, and it all worked great Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 25, 2010 Share Posted August 25, 2010 (edited) Some of the EA82 disc's will not fit inside the EA81 pressure plate. IIRC it has to be an 85/86 disc with the small, round damper spring assembly. The larger "squarish" damper spring disc's will not fit down in the pressure plate and so cannot be used. The recipe for what you are using is: EA81 225mm flywheel (best way to go since you retain the timing marks and no bell-housing mods) EA81 225mm pressure plate 85/86 EA82 4WD clutch disc EA82 5 speed 4WD T/O (yes it's a bit large but will work) Any Subaru pilot (all the same) The other option is to have the flywheel reground to the EA82 step (.815" instead of .900") and use the EA81 flywheel and any off-the-shelf EA82 4WD clutch kit. GD Edited August 25, 2010 by GeneralDisorder Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted August 25, 2010 Author Share Posted August 25, 2010 The disc we used did have a larger diameter spring pack on it. It fit in, and the pressure plate mounted just fine. But we have the clutch cable adjusted all the way to the max, and it doesnt seem to be releasing. Quote Link to comment Share on other sites More sharing options...
subieman Posted August 25, 2010 Share Posted August 25, 2010 uh oh! Hope it all works out! Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 25, 2010 Share Posted August 25, 2010 Flywheel with the wrong step? Was it resurfaced? If it's too shallow it would grab too hard and be unable to release even at full travel of the fork..... Did the two just slide together? No forcing involved or drawing up with bolts, etc right? The pressure plate bolts are tight and both of the dowel pins are located beneath holes in the pressure plate right? I've see a pressure plate torqued down with a dowel pin not properly located and holding up the edge of the plate. GD Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted August 25, 2010 Author Share Posted August 25, 2010 The pressure plate sat flush against the flywheel. I did notice that when the pressure plate was bolted down, all the spring plates on the plate itself moved inwards... instead of sticking at an outward angle. We just finished bolting everything together and it wont disengage the clutch. Ive adjusted the clutch cable to the point where it will not go any farther, and the clutch fork bottoms out when the pedal is pushed to the floor.... but the car wont come out of gear or shift etc. Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted August 25, 2010 Author Share Posted August 25, 2010 uh oh! Hope it all works out! Yeah we're gonna need you to come give JB a ride home Quote Link to comment Share on other sites More sharing options...
subieman Posted August 26, 2010 Share Posted August 26, 2010 Yeah we're gonna need you to come give JB a ride home He's gonna have to wait until Sunday! Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 26, 2010 Share Posted August 26, 2010 Hhhhmmm - try putting some washers, etc under the nut for the clutch cable to get more adjustment. Could be that the cable needs replaced and has stretched? What about the cable sheath? Secured at both ends properly? If that doesn't do it - take it back apart cause something's wrong. The PP fingers going flat like that is normal when you tighten them down. I always tighten them through the starter hole though - makes fitting the engine up to the tranny easier and faster. GD Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted August 26, 2010 Author Share Posted August 26, 2010 Well we went to napa and got another EA82 clutch kit which looks to have a smaller diameter spring pack. we're going to pull everything and start over again. Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted August 26, 2010 Share Posted August 26, 2010 (edited) Cool Glad you got it working! Congrats Edited August 26, 2010 by Crazyeights Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted August 26, 2010 Author Share Posted August 26, 2010 So the new clutch disc worked! We got pix of the differences so maybe it will be more obvious to the ones who do this in the future. now its 11pm, poor JB wont make it to work tomorrow but I can't call in sick. I gotta get some sleep! Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 26, 2010 Share Posted August 26, 2010 So it was the damper spring/PP interferance problem? That was my first thought since I've looked at that problem before and noted the intereferance between the two. Plus Jerry brought it to my attention when I was at his place and got my 5 speed and his kit. Then it came up on the board a while back and it was determined that 85/86 has the compatible damper springs. GD Quote Link to comment Share on other sites More sharing options...
Jibs Posted August 26, 2010 Share Posted August 26, 2010 Thanks for all the help. I just got home, drove the hatch with the 5 speed from Sacramento to Reno (130 Miles) without trouble. Now I get to see if I can take that other pressure plate back. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted August 26, 2010 Share Posted August 26, 2010 I had this same problem recently with my 5spd swap. I would suggest using an EA82 Flywheel. The EA81 flywheel is about 8mm thicker. (extra meat on the crank mating area) Moves the friction face and the whole Disc/PP assembly closer to the trans. This leaves very little room for the Throwout bearing between the PP and the trans. Also, the EA81 Pressure plate fingers don't mate well to the EA82 throwout bearing. Quote Link to comment Share on other sites More sharing options...
suberdave Posted August 29, 2010 Share Posted August 29, 2010 awesome! glad to hear it all worked out... Quote Link to comment Share on other sites More sharing options...
subieman Posted September 14, 2018 Share Posted September 14, 2018 It's 8 years later... still need help? haha 1 1 Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted March 6, 2019 Author Share Posted March 6, 2019 On 9/14/2018 at 4:59 PM, subieman said: It's 8 years later... still need help? haha LOL Jeremy! Quote Link to comment Share on other sites More sharing options...
