April 14, 201114 yr Author I can't 100% confim but I think that shifter bushing linkage is part # 35041AC110 I need to doubble check with the dealer since the opposedforces.com site just calls it Rod-complete gear shift
April 15, 201114 yr Author My ultra Grey came in the mail today I know its not really the right stuff to use still but what else can I use it on?
April 16, 201114 yr Author Ah ok ugh well I ran into another roadblock with the dmv so it looks to be like Tuesday now when I can finally bring the car home.
April 16, 201114 yr Author spam? Anyways I'm about to order a few parts from Subaruparts and just my luck the friken grill clips are going to take longer then the other stuff.. Anyone know if dealers keep this on hand or is it all something they need to order? Anyways as far as the transmission side of things I have the two clips in the order for the TOB but what about that clip retainer which looks to be behind the clutch fork? Should that be ok? That shift rod bushing I will just get locally once I can figure out which design it is since it appears to have changed mid model years. Edited April 16, 201114 yr by 1-3-2-4
April 17, 201114 yr Author Is amazon the only one with the best price on the exedy clutch kit? http://www.amazon.com/EXEDY-KSB04-OEM-Replacement-Clutch/dp/B001B5EMS4/ref=wl_it_dp_o?ie=UTF8&coliid=I1NR2LJRQSQ9UJ&colid=1NH884YY0W7K2 $141.95
April 19, 201114 yr Author Driving the car home I dont have 5th gear! Also sometimes the clutch pedal sticks to the floor
April 19, 201114 yr Author Car does not use a clutch cable.. I did a little video but will post it when I get back in.
April 19, 201114 yr Sticking clutch pedal? Could be that you need a new slave cylinder. Plenty of info on this board. Search for 'clutch slave cylinder'.
April 19, 201114 yr Author Sticking clutch pedal?Could be that you need a new slave cylinder. Plenty of info on this board. Search for 'clutch slave cylinder'. yeah I figured it could be that the gearing on this car is awesome in what little bit I can use..
April 19, 201114 yr The gearing is good for off the line but it is bit of a screamer on the highway. I am clocking around 3300 at 70.
April 19, 201114 yr Author the extra power over the 2.2 is nice but I was at 4K at 60 MPH because I could not get 5th 3/4 went to a 1/2 in about 90 miles
April 21, 201114 yr Author Hmm I think I have a break in the weather on Friday albeit cloudy... because I have no 5th gear I'm going to go ahead and take off the rear housing cover. I'm not sure if the nut back off or the shift fork is bent. While I'm at it I should do the shifter linkage.. this is the sloppiest shifter ever I noticed subaru has like 3 different part numbers for the shift fork for 5th gear.. one being mark 4" and the other being mark 6" and the other not saying anything at all *edit the mark number should be stamped on the fork Edited April 21, 201114 yr by 1-3-2-4
April 21, 201114 yr if you're pedal is sticking to the floor and you need a new slave cylinder, let me know. i have a brand new oem one that i'd let go for cheap. good luck with your troubles.
April 21, 201114 yr Author I will let you know Can the hydraulic system be done by one person as far as getting the air out? I was going to get something to suck the fluid out so the air wont be trapped in? i get to drain the tranny fluid tomorrow so I will see how bad things look.. just going to use ramps tomorrow How much do you think that this nut on 5th gear backed off? Edited April 21, 201114 yr by 1-3-2-4
April 21, 201114 yr When I couldn't get into 2nd gear on a Legacy I refurbed it was the gears themselves - they had stripped all the teeth off and jammed up the engagement dogs. It wouldn't even try to go in. Transmission was shot - tons of metal. I would just pull it - easier to work on. You'll probably find the tranny is toast - they just don't last and a replacement is the best option. GD
April 21, 201114 yr Author It moves into 5th with no problem it's just 5th is not catching I have to pull it anyways but the tranny has a leak I think it might be where the input shaft might be it's hard to tell right now. I was trying to do a recording of the transmission but my recorder was acting funny for some reason 5 min drive and only 1 min and 45 sec worth got recorded. I did take some shots under the car
April 23, 201114 yr Author man this is crazy I'm going to buy a transmission in a few weeks.. I hope that car parts site is correct on prices.. I've never heard of this site before.. Do they have core charges or something? The prices are all over the place.. in like 5 weeks I'm going to be driving to Michigan.
May 6, 201114 yr Author Got the tranny jack so next week I should have the new one in got a discount too on a beat up china box.
May 6, 201114 yr Author I got a 2 Lb rubber mallet I hope that's good enough to tap some areas free? I have to look at the FSM but not many bolts that mate to the engine right like 5ish?
