1984 GL Wagon Fwd Build
Lookin Great! :slobber:
Wish I had a set of those wheels... :slobber:
Thanks! They do look awesome on there. Glad I got them when I had the chance.
You took it out in the snow!!! :slobber:
The rear bumper looks good on there, the front does need a little, something.
Is the Rack factory? Or is that a retrofit?
Yeah I took it out in the snow :cool: they don't salt the dirt roads here because the salt would just turn them to mud. It was pretty frozen this morning so I didn't see any harm in a mile drive.
I'm thinking up designs already for a new bumper :popcorn:
The rack is factory. At first I really didn't like it (when it was chrome) but now that it's painted I really think it makes the car. Your car has the other style, I think it was called the four seasons rack. Which is what my 82 wagon has. I like that one a bit better, but without one these cars just look too plain.
  • Replies 448
  • Views 91.9k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • It's all back together now. I took it for a drive last night, seems to go pretty good. I need to time it now and then I think it will be great. It does have some check engine light issues right now, b
  • Started working on the control arms for the five lug swap today. I bought a tool from Mac for the job, worked well on the largest drill I had around. Only took me a few minutes to drill each of them o
  • Worked on the control arms more tonight, got both bushing removed, and spent some time messing around with them and welding them. I'll just say they are a fair bit stronger now. I put the bushings in
You are lucky over there with no salt. WI just pours down the salt, I actually think the waste a lot of it for no reason.
Yeah, I absolutely love that rack, It does look good black. Its better then mine (I'm also missing the crossbars which sucks)
Subarus with no rack suck, the roof pops A LOT. At least in an EA82.
We use tons of salt as well, just not on dirt (well a tiny bit) but nothing like the pavement here. My legacy is taking it hard this winter....
I may have some cross bars for that rack from when I parted the turbo wagon. I'll have to look. It probably won't be until next weekend at this point but I'll let you know if I fine anything.
Chip! You joined a Subaru forum? Now that is hard to believe :grin:. Welcome aboard, now we just have to get you in one of these fine automobiles.
And thanks for the compliment.
Haha I'll stick with the Saabs and Benzes for now but I do like your WRX I would totally rock one of those someday.....
Cool, that'd be nice!
Cheers,
-Tom
It's lookin' great Shaun!
I gotta find that same roof rack. Mine is long gone. I can wait though. When I re-paint mine I may just weld up the mounting holes and go without one.
Also, thanks for the info on the BRAT 5 lug swap.
Thanks! I debated welding mine and putting another rack like a basket type, but I'm glad I stuck with the stock one. It fits this car pretty well. And anytime if you need any more info on it let me know!
  • 2 weeks later...
Center caps came in! About time. The ones on the left side are a little loose for some reason. I may heat them and bend the tabs out, or just put some black tape around the edges so they sit better. Schools wrapping up (last month!!!) so I haven't had much time to work on this. I have however taken advantage of my snap-on discount $3500 dollars worth of stuff ordered today :headbang:
If you're wondering why it's sitting outside, it's because I picked up a new project...
72 beetle, picking up an engine to rebuild for it tomorrow hopefully!
how did you get the badging off without breaking them?
This getting registered tomorrow? Possibly insured and inspected as well?! I think yes! I'm swapping the plates from my other ea81 so it is kind of a sad day at the same time. I need to find a new body for that one. I can't wait to drive this thing.
Edited by 1982gl4
On the road! Drove it around all day today and it was awesome. Went to DMV this morning 58 dollars later I waked out with my transferred plates! Had some charging issues with it due to a junk wiring repair. I swapped out the alternator before realizing this. All was well as it charged after that and the wiring fix. Gauge on the inside is still off a bit, but it's charging 14.3v so good enough for me. Needs front brakes that's next. I have rotors I need pads they shake like crazy, but that is not going to stop me from driving it back to school tonight :)
Put on 100 miles so far! She's pretty slow, but I don't mind. I'm in no hurry. I would like to do FI to this I think. I'm going to start looking for a Loyale that's a rusty heap, which may be challenging as there are none of those left up here. But I'm going to keep an eye out.
Some issues with the car thus far:
Brakes, the rears need adjusting, and the fronts need to be replaced, stops fine, just shakes.
Heat, I have none, not sure why coolant level is great, and temp stays right where it should. I'm going to flush the heater core with a hose. I also may look into the ducting to see if it is clogged of I forgot to hook something up.
I had some issues with the charging system due to a P.O's repair using tape and twisting wires together :-\ Fixed that, it's charging fine, but the gauge reads low.
Fuel gauge doesn't work.
Distributor is well.... On its way out. May try to get a use or a new one, or try to fix the one I have.
Needs to be inspected in the next 14 days.
Then I have to finish all the fun things I have been plaining for it :cool:
It's amazing all the people that have asked me about it this far, for some reason they all think it is older than a 1984. Not sure why, maybe because they all rusted away long ago. Man do I love driving this :burnout:
Going to work tonight to address some of my issues :rolleyes: Oh and I'm getting 25mpg with it right now. I don't think that that's too bad for it's first week out in a few years. I'll be adjusting the timing and doing some other stuff to hopefully improve it :cool:
Rear brakes most likely need adjusting. But,,, you'll find the adjusters are froze up.
Rockauto lists them for the EA81's, and the EA82 FWD ones are the same. Atleast going by Son's '88 GL10 FWD Wagon they are.
Good to see you have it on the road.
Here's hoping your Inspection goes well. :drunk:
I spent some time freeing everything up while it was at work the last time some time with a torch and vice-grips they came out of it. Everything went pretty smoothly tonight. I have new front brakes so the steering wheel is no longer shaking out of my hands :rolleyes: I spent some time painting the hubs up, along with the calipers. The rears I adjusted up, and they are 100% better, but I think there may be some air in the lines as the peddle is a bit low. I'll bleed them tomorrow. I also changed the trans fluid with synthetic 75w90 shifts like butter now. I may go back down tomorrow to change a bulb I noticed that was out tonight, find some muffler to put on along with an ansa tip I picked up. That's all for tonight.
I waited for a warm day (could use a hair dryer or a heat gun as well) and used a very small screwdriver to work around the edges, once I've done that I get a larger flat head and pry it off starting at the edge by the door, and moving lengthwise toward the front of the car. I've had ones where they are unavoidable to break in those cases I've glued them back together.
Washed it this morning. Also cleaned the interior up some as well.
What's this on my windshield :cool:
Inspected!
Today I also pulled the front brakes back part due a noise. Turns out one of the anti rattle clips had folded up and was grinding on the rotor. I took that out, cranked the rears up some more, and now I have some brakes. Peddles like a brick :headbang: Changed out the bulb that was bad, and I adjusted the e-brake. I also pulled the heater fan out and took some junk out of there. I'm still not sure why it doesn't have heat... Has a new subaru thermostat, coolant level is good, and the doors in the dash are working....
