October 6, 201114 yr Just wondering if anybody has ever run these on stock wheels? If so any handling/ clearance issues. My Loyalle is not lifted. I found these tires, a snow tire with studs im thinkin of removeing, for cheap. The main problem, as we all know is the lack of aggresive 13" tires. I only use my Subie in winter, maybe 3k miles/year, so tread wear is not really an issue. Now clearance and handling are though. Let me know! Thanks
October 6, 201114 yr When i got my scoob (1990 loyale wagon) it had P185/70R13/85T's all around, (assuming thats the same size your asking about) stock height and the tires did just fine, no clearance issues at all, but now i am running 175/70R13/82H cause they didnt have my original kind in stock. i hope this helps. Cheers
October 6, 201114 yr 185/85r13's will fit your loyal just fine... if you can find them. Those are my preferred tire size for the stock rims.
October 7, 201114 yr What brand/model of tires are they? I might be needing some snow tires this winter as well, and the local shops only seem to have 175/70/13s in stock...
October 7, 201114 yr Good luck finding that size. Every year buying tires in 13inch gets a bit more difficult. I took what i could and got 185/70/r13s for my coupe and they look good and handle ok. Honesty no tire is really going to help your handling that much with a stockish suspension. I have a good amount of mods to mine and handling is still Meh.
October 11, 201114 yr I Believe that 185/85/13" could be too Tall... Could Rub the Fenders in certain Curves. I Used 205/60 R13 flawlessly on the Subaru EA82 Wagon, on Subaru steelies, mags and Aftermarket wheels; here is a Comparison Side by Side Between 185/70 R 13 and 205/60 R 13, the 205 is the Fat one on the left; Both has the Same Tallness: Kind Regards. Edited March 28, 201610 yr by Loyale 2.7 Turbo misspelled word
October 11, 201114 yr I had those on my stock height 84GL, and had no issues with fender clearence. Those... Which ones? Edited March 28, 201610 yr by Loyale 2.7 Turbo
October 12, 201114 yr Those... Which ones? The 185 x 85 - 13s. sorry I didn't specify:drunk: it wasn't until I installed my 195x75-14s that I had to cut my fenders
October 13, 201114 yr If in Oregon-Washington Les Schwab Tires has 185-80-13 Good luck with that. Last year I bought basically the last set that any les schwab had seen for a long time. Called around to 3 different locations before I found a set. They are the Wintertrac tires, and they are the only tire I could find in 185/80/13. They are also a snow tire. The 185/80/13 fit with no problems what so ever with some room to spare, so I imagine that 185/85/13 might fit. But finding that size tire, good luck!
October 13, 201114 yr Well... we have plenty of 13" Tires here.Have you already searched for 13" tires online?http://www.onlinetires.com/user/vehicle/tires/allbrands.html Edited March 28, 201610 yr by Loyale 2.7 Turbo
October 14, 201114 yr Author Ive allready got the tires. I just wanted to check to see if anybody had run these before without a lift.
October 14, 201114 yr I have an extra set of wheels and had knobby 185/80s with studs mounted on them for winter. Now I can't find them anymore.
March 27, 201610 yr Those old 185/70r13s are wearing in the front and I will soon be shopping to replace them.
March 27, 201610 yr I always thought wider tires on the Loyale looked much better than the standard 175/70R13. Is 185 the widest tire that will fit ?
March 28, 201610 yr I always thought wider tires on the Loyale looked much better than the standard 175/70R13. Is 185 the widest tire that will fit ? Look my post above, 205/60 R13 fits great, on standard Subaru 4X140 steelies, Subaru Mags, and Aftermarket Wheels. Kind Regards.
March 28, 201610 yr I would think 205's on stock 5" wheels would be a little wide, especially with a lower profile. Suitable width for a 5" is 155-185. A 6" wheel is 175-205. Maybe ok on a hellaflush Civic or AE86 Corolla. (And yes, I'm sure several people have run 225's on a 6" wheel with `no problem')...
March 28, 201610 yr Thanks guys, I'll have to double check if the standard Loyale is a 5" or 6" wheel.
