Drill Bits?
What drill bits do you recommend and where do you buy them? Cobalt, HSS, ect? I know there are different types for different jobs. I am trying to avoid buying another cheap set;)
Really depends on what you are drilling.
For mild and hardened steel I have found Champion Carbide to be heads and shoulders above anything I have available here in town.
Luckily we stock them at my work. So I get a screaming deal.
Ive got a complete set of XGO BlackGold bits by Champion, have had them for 3-4 years now, abuse the hell out of them, and have yet to break one, or overheat/ruin one. They really are outstanding bits. :headbang:
BOSCH. best i have used..made in Germany.
And, a drill bit sharpener....
Edited by bheinen74
Thanks - that is exactly what I was looking for. I drill everything from aluminum, to mild steel, rusted heat baked and broken exhaust parts, ect.
I realize I will probably need several types for different jobs, and Champion and Bosch are some good recommendations I can start with. I have also had good luck with a few Hitachi singles I have picked up at a local hardware place in a jam.
My friend (30 years in the military) can pick up any drill bit broken or not off of the floor and a quick pass on a bench grinder and it will cut through anything:clap: I haven't even got the drill doctor down yet:rolleyes:
Edited by Crazyeights
yeah; awesome.
Same, my dad can take broken bits and make them drill better than new with his bench grinder. He was a mechanic professionally for 41 years at the same GM garage though. He can take pretty much any bit and make it sharp. He gave me a drill doctor, cause it was never beneficial to him, they don't sharpen as well as his self ability with a grinding wheel, eye/hand/feel.\
It is really only the very tip end blades that do the cutting, and once you get that down to how, no biggy, I wish i would learn someday. Maybe i will ask him for a session of doing some of my old bits that i tend to ruin. He also gave me a bench grinder on a stand. I used the drill doctor once, but it is a pain to figure out, i would rather know how to use the grinder wheel.
Edited by bheinen74
I knew a guy once that did a lot of side jobs at home on cars/farm equipment. He said he only ever bought left-hand twist drills. Works just as good as 'normal' and great at stuck/broken bolts removal.
I use hss drill bits daily on alum, steel and stainless ( if the stainless is 1/8th or less ) and countersinks as well. Something like rapid tap or stick wax is important for keeping the bits cool and sharp. I prefer to buy from an outfit like fastenal vs big box retailers.
Bosch bits are not made in germany.
Most are made in China. Some are made in the USA.
Hey, the Chinese ones are without a doubt made with STEEL that CAME from the USA :popcorn:
