Weber carb for my 87 gl?
Not to bad on the price. You can get a new one on Ebay for $199. This adapter is better then the two piece redline adapter but then you cant use the tall air filter. http://www.tdperformance.com/site/?d=108&dt=108&Keyword=2107
Yeah maybe i will just pony up and buy one for 199. Can someone link the adapted, air filter, and any other parts I will need?
  • Replies 189
  • Views 30.6k
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Its not hard at all. Just take your time,read through that right up on the basic swap and worry about pcv and stuff like that later.
Here is the air filter assembly to use if you go with the Datsun adapter.
http://www.ebay.com/itm/NEW-Chrome-Air-FIlter-DGV-DGEV-Weber-Carbs-1-75-Tall-/130573053309?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item1e66c2ad7d
Use a piece if window screen to go over the Water hole on the intake under the carb and put some JB weld over it and let sit overnight before you put the adapter on. Make sure to smooth it out as best as you can so you don't get any unevenness under the adapter. Of course make sure the intake is clean of any old gasket material.
After its on follow these instructions to tune it.
http://www.redlineweber.com/html/Tech/carburetor_set_up_and_lean_best_.htm
Edited by desertsubaru
I might get flamed but I am learning. Can this be done on an EA71?
Has anyone dynoed there car with the weber installed to see how much Horsepower they are getting? I am interested to know. And what are the average miles per gallon you guys are getting? Just wanting to know how worth it, it will be.
I Swapped a Weber on my BumbleBeast Years ago... and I will Never go Back to an Hitachi carb anymore.
Yes, it Worth it!
Click on my Avatar to reach my Weber Swap Writeup with Pics and alternative adapters, part numbers and Proper PCV Routing...
Kind Regards.
  • 3 weeks later...
Alright talking with my dad, I think he is going to fund me getting a weber this summerish. hoping I can get it installed myself. I am scared. SHOUTOUT TO PEOPLE WITHIN 150 miles or so of BIG SKY, MT. Looking for help with a swap.
Do I want a dgev or a manual choke?
okay making a list of everything I need. And literally everything. Anything else besides these three things?
http://www.webercarbsdirect.com/32_36_DGEV_p/22680.033b.htm
http://www.ebay.com/itm/130573053309?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_3335wt_1308
http://www.ebay.com/itm/350528634213?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_1707wt_952
Edited by Moosen
If your hitachi's electric choke circuit is still functional, go with the electric choke.
Its as simple as extending one wire, and crimping one connector. They the Weber choke functions like stock. No need to run a manual cable, and the choke is activated at the push of the pedal.
Your parts list looks good. Though I dont know for certain if that is the correct adapter, and personally I think the weber air cleaners are garbage.
I dont know anything about no wire? ahaha someone tell me about this? does my car even have a wire?
link to better air filter?
Your list is good. As for the air filter K&N makes one that size, I don't have a link but a google search will bring it up. The choke wire hooks on a round plastic thing on the carb. Usually one wire blue in color held on by a tiny nut. This is one of the easy swaps to do on a sube.
Alright that is good news to hear. I am looking to get it done in one day.
Is this it?
https://www.pegasusautoracing.com/productselection.asp?Product=3812
Alright guys I will be getting a new carb and stuff tonight it looks like. should get here next week. Hoping to basically just be able to bolt it on in one day.
One thing I am concerned about/don't know how to do it, is the water valves and pcv stuff (basically what do I need to plug?) I read Loyale 2.7's thread on it, but basically got confused because there are so many edits to it that say this is the way, no this is the way. So can someone clear it up for me?
Edited by Moosen
I ditched the weber/empi style filter all-together.
I retrofitted the factory airbox to the weber :headbang:
1. isn't that an ea71?
2. why would you do that?
*ea81
*because the filters available for that carb are CRAP. Its very hard to beat the filtration of the much larger, stock paper filter.
It also lets me utilize the exhaust heat stove for cold weather operation.
*ea81
Oh and yeah i meant 81 my bad.
But it doesn't look as cool :( Was it hard to modify?
i think it looks way better than that chinsy POS filter that comes with the weber. And with as clean as my GL is, I like having the ability to keep it looking OEM.
Not terribly difficult.
A few more pics here
http://www.bonnefinstudios.com/kwb/automotive/RU/RUweber12.jpg
http://www.bonnefinstudios.com/kwb/automotive/RU/RUweber15.jpg
http://www.bonnefinstudios.com/kwb/automotive/RU/RUweber16.jpg
http://www.bonnefinstudios.com/kwb/automotive/RU/RUweber20.jpg
As well as a vid...
As well as a vid...
Oh god I can't do metal fab. I am gonna get this k&n will it work? http://www.knfilters.com/search/product.aspx?Prod=56-1070
edit - nevermind not spending 80 bucks on that
Edited by Moosen
Yes that filter setup will work. As for the PCV routing and vacuum hoses i used Loyale 2.7's first setup in his writeup. You need one vacuum to brake booster but thats in the intake and will not be changed by swapping carbs. 1 off the front of the carb to the Distributer and one to your heater controls off the intake on the passenger side of the car.
Still confused haha. Can someone do a video? I am a very visual learner. Anyways carb, air filter, and adapter all ordered just now.
So my biggest concern by far is allt he hoses. I have no idea what hose does what , So I am worried I will not hook it back up right.
Once you weber it you will ditch most of the hoses. You can see the vacuum line to the HVAC controls and the PCV lines and not much else in the pic. No more EGR or Evaporation canister. (this is my car at WCSS 5)
