March 7, 201214 yr Wanting to plug the erg pipe that runs from the passenger side head to the intake. Is it an NPT thread or metric or standard? All the bolts and plugs in my tool box didn't fit:mad:
March 7, 201214 yr Author I have blocked off the egr with a plate. Are you sure that pipe is not venting anything back into the manifold? If for no other reason than to clean up the messy look if its not necessary. Thank you for your reply.
March 7, 201214 yr Block off plate isnt even neccesary. Without a vacuum supply the valve is its own block off plate. The thread is definitely metric.... Probably M16 x 1.5. But you can easily make a plug from the old tube with a bit of welding. GD
March 7, 201214 yr Author or brazing? Looks like the tube is brass. Thanks for everyones input. Love this forum.
March 7, 201214 yr The tube is steel. Brazing would work I suppose but typically welding is just easier. GD
August 29, 20178 yr Old thread, but I measured tonight and can confirm GD's estimate of 16mm is spot on. Bel-metric carries some fairly cheap M16x1.5 plugs if you don't have access to a welder.
August 29, 20178 yr Or cut the tube just past the fitting, mash it flat with a hammer, then fold it over and pinch it tight with said hammer.
August 31, 20178 yr Think seen spark plug scewrd in same hole make it a fourteen mm . is that 2.0 mm pitch?
