i need a ea guage wire diagram
Voltage isn't messed with - it should already work. That gauge pulls it's reading from the cluster power source. Maybe you meant to ask about hooking up the alternator?
VSS is generally pretty easy to trace - just follow the wires from the hall effect sensor on the speedo to where the speedo bolts to the circuit board. Then follow the traces to the connector and determine which pin they come out on. It's probably a yellow wire with a red trace.
Temp you shouldn't have to mess with - just connect the wire from the EA engine's temp gauge sensor to the EJ temp sensor. It will read low but it will work. Basically if the gauge gets up to half-way it's overheating.
sorry to hijack, but would you say alternator down around 13v-13.2v should be replaced?
If you are getting that reading directly off the back of the alt then yes it's not charging right. That's a full volt low.
If you are registering that at the battery then you could just be seeing voltage drop from the alternator to the battery so recheck at the back of the alt.
yep alt. is bad lights went very dim and engine stalled and wouldnt start up. i tested volts on the alternator where the big white wires connect and 8.2v at idle and about 6v at higher rpms so gonna have oreillys test tomorrow to be positive and get a 96-99? one and convert connector for higher amps
95 to 98 is the best bet. The reason we do that is they are only $75 at the dealer due to a dealer initiated reman program for a recall campaign in those years.
Make sure you have switched power to the yellow wire on the alt like we talked about - if you don't the alt won't charge. You also need the field flash wire hooked up through the idiot light in the dash or the alt will not charge. If you have the gauge cluster disconnected the alt will not work....
Insure that you have it hooked up correctly before you determine the alt is bad.
