Introducing the Subercoupe Now with 50% more cyl’s and 100% more RWD!
I would love to see an in car video if you get around to it.
  • Replies 86
  • Views 30.8k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
Got my 2.7 in pulley today. hope to have it on in the next day or two...
This thing will be a ton-o-fun with 6-7psi...
-=Suberdave=-
P.S. Durania, i will try to get an in car video soon...
Have you done another dyno pull since installing the new clutch? Curious to see what power you're putting down.
No i haven't. didn't see any reason to blow any money on the dyno, when i would just have to do it again after the new pulley.
-=Suberdave=-
  • 4 months later...
nope. i talked to some VW guys that put the EG into buses, they said they never use an extra pump.
the hottest it has gotten is 201*F and that was in stop and go traffic on a 85*F day. normally runs right at 194*F.
-=Suberdave=-
Yeah its interesting, I have a few Fiat X1/9's and a Lancia Scorpion, they have coolant tubes running from the radiator in the front to the engine in the rear, nothing extra besides an old 70's design typical looking water pump run off a V-belt pulley on the side of the engine. Never a problem I guess. I'm planning custom engine-swaps also on a couple of those cars in my future..
Yeah, in for new updates with your awesome Sub!
  • 1 year later...
Saw your vid from the drags. As others have said, such a shock to find out the drivetrain.
Definitely in awe. I've always wanted to put a WRX engine & FWD trans (with LSD) in the tray of a Brumby/Brat.
Have you had any understeer issues with the weight gone from the front? I know some proper converted manufacturers have had this issue (Renault Clio V6 :P)
If you have some engine bay cooling issues, a pair of side intakes from the first model Toyota MR2 grafted between the doors & rear wheels would suit the square shape.
Can you tell how you've held up the engine?
And I'm also curious what rear suspension you're using.
  • 2 weeks later...
Like the concept, Great video ... :)
Cheers, Bantum ...
I'm wondering how you made the shifter work?Ive thought about mid mounted engines before but I could never work out how to get the shifter to work.
  • 2 weeks later...
2wd 4eat with high stall converter have pushed the converter to 3800 rpms makes for strong launch
