ea82 inhaling coolant after weber swap
hate to start another weber question thread, but I need some assistance. I'm sucking coolant through my intake via the hot water outlet after my weber swap. It seems the supplied cardboard gasket isn't functioning as a block-off, does anybody have a viable solution? Thanks!
EDIT: nevermind, it seems a schmear of JB weld should do the trick, but if theres a better way let me know!
Edited by herb
If you do a search for Weber you can find what other people did.
I use a bit of window screen to keep the JB from seeping down the hole and just forming a new hole again. JB weld is thick but will easily (but slowely) seep into small areas and it can be a pain to get it to stop flowing into the hole and plug it.
Yep. ;)
