herb Posted October 11, 2012 Share Posted October 11, 2012 (edited) hate to start another weber question thread, but I need some assistance. I'm sucking coolant through my intake via the hot water outlet after my weber swap. It seems the supplied cardboard gasket isn't functioning as a block-off, does anybody have a viable solution? Thanks! EDIT: nevermind, it seems a schmear of JB weld should do the trick, but if theres a better way let me know! Edited October 11, 2012 by herb Quote Link to comment Share on other sites More sharing options...
Hitoshi Posted October 11, 2012 Share Posted October 11, 2012 If you do a search for Weber you can find what other people did. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 11, 2012 Share Posted October 11, 2012 I use a bit of window screen to keep the JB from seeping down the hole and just forming a new hole again. JB weld is thick but will easily (but slowely) seep into small areas and it can be a pain to get it to stop flowing into the hole and plug it. GD Quote Link to comment Share on other sites More sharing options...
Pooparu Posted October 11, 2012 Share Posted October 11, 2012 I use a bit of window screen to keep the JB from seeping down the hole and just forming a new hole again. JB weld is thick but will easily (but slowely) seep into small areas and it can be a pain to get it to stop flowing into the hole and plug it. GD Yep. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted October 11, 2012 Share Posted October 11, 2012 Look Here: ~► http://ultimatesubaru.org/forum/showthread.php?t=74206 Kind Regards. Quote Link to comment Share on other sites More sharing options...
