ferp420 Posted March 29, 2014 Share Posted March 29, 2014 ive found that if i can get to the back side of the clip i can use a small deep socket and slide it over the tabs that stick thrugh the body and the clips come right off with out breaking cant get to all of them though 1 Quote Link to comment Share on other sites More sharing options...
Scooner Posted March 29, 2014 Share Posted March 29, 2014 Nice, yeah that adhesive is pretty awesome especially if you use some alcohol to clean the surface it attaches to! Those clips were the same on all of the EA82s i think, i took molding off of three different wagons trying to save some clips ranging from an 87 to a 93 Loyale. By the way, the junkyard east of the super walmart in fort collins, co has an ABUNDANT supply of subaru parts! Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted March 29, 2014 Share Posted March 29, 2014 ive found that if i can get to the back side of the clip i can use a small deep socket and slide it over the tabs that stick thrugh the body and the clips come right off with out breaking cant get to all of them though Good idea, Thank you! Quote Link to comment Share on other sites More sharing options...
ruparts Posted March 29, 2014 Share Posted March 29, 2014 Hi, i looked this up in my 88 parts book> 91017 GA750 is the subaru number for 87-88 vehicles. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted March 29, 2014 Share Posted March 29, 2014 I have an 86 with the glue on trim...... When I painted the car, to reapply the trim I used "the RIght Stuff" sealant/adhesive.........masking tape for the first 24 hours to hold mouldings in palce while it sets........and it's been on there for 3 years now..... Might be easier than trying to find clips. Quote Link to comment Share on other sites More sharing options...
Discombobulated Posted March 29, 2014 Share Posted March 29, 2014 (edited) Nice, yeah that adhesive is pretty awesome especially if you use some alcohol to clean the surface it attaches to! Those clips were the same on all of the EA82s i think, i took molding off of three different wagons trying to save some clips ranging from an 87 to a 93 Loyale. By the way, the junkyard east of the super walmart in fort collins, co has an ABUNDANT supply of subaru parts! Good to know this the locals around here just scrapped the last 3 loyales I have been picking off of:( but I ended up using some 3m double sided and it worked great, didn't want anything too permanent but I guess it doesn't really matter as the trim needs to stay forever:) finding out real quick to think of good ways to take stuff apart on these cars, every part I need to replace is broken but the part that is good that the broken part is attached to breaks taking it off so I have reversed my plan...... Edited March 29, 2014 by Discombobulated Quote Link to comment Share on other sites More sharing options...
Scooner Posted March 29, 2014 Share Posted March 29, 2014 That's a good idea, my wife actually suggested using a type of glue or epoxy. I called the subaru parts shop at the dealership this morning, he looked it up and said no way. They've been discontinued. Figured it wouldn't hurt to try. Quote Link to comment Share on other sites More sharing options...
coxy Posted March 29, 2014 Share Posted March 29, 2014 I think you will find from that era trim clips were all nylon the abs revolution started in the early nineties along with that hell to remove (Like as in an angle grinder) Sikaflex they use these days to even glue replacement body panels on with. Quote Link to comment Share on other sites More sharing options...
Scooner Posted March 31, 2014 Share Posted March 31, 2014 My fix for trim clips, drilled and tapped 8/32 screw, used adhesive mounting tape and fender washers with nuts on the back side. Workin awesome. Quote Link to comment Share on other sites More sharing options...
l75eya Posted April 1, 2014 Share Posted April 1, 2014 I think you will find from that era trim clips were all nylon the abs revolution started in the early nineties along with that hell to remove (Like as in an angle grinder) Sikaflex they use these days to even glue replacement body panels on with. Sikaflex! I used that stuff to seal up the gps antennae installed on the roof of the nyc busses. There's a chemical remover they gave me to remove the stuff, works great. Aptly named sikaflex remover. Quote Link to comment Share on other sites More sharing options...
