Meeky Moose Posted March 12, 2013 Share Posted March 12, 2013 was working underthe hood today, removed all of the ac components.. it still had a charge after 29 years.. compressor was locked up.. also replaced a bunch of rock hard vacuum lines, fixed the pinhole leak in the radiator. basic stuff.. started it up, reved it a couple times by hand and the throttle cable popped out of its grove and pinned the throttle wide open.. so it revved wide open for about 5 seconds, until i got around the car and dove in the window to turn it off.. funny part is now it runs way better, but at idle is has a lope to it almost like a miss.. i replaced plugs to make sure.. no change.. so the high rev musta "cleaned" some carbon offa something i'm assuming.. deffinitely more power now too.. anyways i don't recommend this cleaning procedure to anyone, lol.. it coulda been bad had the motor not been really sound... Quote Link to comment Share on other sites More sharing options...
NorthWet Posted March 12, 2013 Share Posted March 12, 2013 In the '60's, it was referred to as an "Italian Tune-up"... Ferraris, Maseratis, et al, would tend to foul their plugs loafing around in city traffic, so the owners would take them for a right good romp on the highway. If this is a solid lifter EA81, you might want to recheck the valve clearances. Quote Link to comment Share on other sites More sharing options...
AKghandi Posted March 12, 2013 Share Posted March 12, 2013 (edited) after plugs and oil that's the first thing I do with any subie I get, makes a world of difference especially if the previous owners were elderly. on these motors, as long as its got oil it should be ok. ive seen one of these with a rod knock revved to 7k for a solid 10 minutes. it still ran after. Edited March 12, 2013 by AKghandi Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted March 12, 2013 Share Posted March 12, 2013 if it does no harm, I'd say it was the right way! Quote Link to comment Share on other sites More sharing options...
bratman18 Posted March 12, 2013 Share Posted March 12, 2013 I've redlined most of my subarus, with the exception of a coupel, on a daily basis. Never bothered anything. Quote Link to comment Share on other sites More sharing options...
Twitch de la Brat Posted March 12, 2013 Share Posted March 12, 2013 As has been said before, a redline a day keeps the mechanic away Plus, its not like you had seafoam in the crankcase, or did you? o_O Twitch Quote Link to comment Share on other sites More sharing options...
rpholz Posted March 12, 2013 Share Posted March 12, 2013 The xt6 isn't happy till you do a pull to 7500 rpms lol. Not sure where the rev limiter kicks in tho.. Quote Link to comment Share on other sites More sharing options...
Meeky Moose Posted March 13, 2013 Author Share Posted March 13, 2013 heh no seafoam in the case.. its a hydro motor too.... i hadn't driven it since then other than out to the end of the driveway to park it on the street last night.. i got in it this morning, started it up, and it blew the oil filter off.. not just rattled it loose, i mean blew it clean off, 3qts of oil on the ground.. i didn't notice the oil pressure higher than the normal 50 or so on the guage.. ohh well, it got a new filter, oil and some mmo tonight.. took it around the block, let it run for 45 min while i cleaned up the oil in the street.. seems fine.. gonna drive it my normal 60 mile commute tomorrow and see how it does.. Quote Link to comment Share on other sites More sharing options...
NorthWet Posted March 13, 2013 Share Posted March 13, 2013 Free over-reving tends to be limited by valve float, which puts nasty loads on the valve train, depending on what part is provoking the float. Bent push rods can result, as can valve spring damage and fatigue (valve springs tend to surge at high RPM). Quote Link to comment Share on other sites More sharing options...
l75eya Posted March 14, 2013 Share Posted March 14, 2013 I'll be sure to try and bring the Loyale up to 8k on the way home tonight. Quote Link to comment Share on other sites More sharing options...
