EA71 Pistons
  • Replies 63
  • Views 19.7k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • turbosubarubrat
    turbosubarubrat
    the first link first result is the best deal at $140 with pisons and rings or by pistons $50 apiece and have to buy rings http://www.ebay.com/sch/i.html?_trksid=p4712.m570.l1313.TR0.TRC0&_nkw=sub
  • Crazyeights
    Crazyeights
    I have a HP EA81 going together now.  I have sets of EA71, EA81, and EA82 SPFI pistons available.  I'll install one of each type of piston (without any rings) to see what the measurements are at TDC.
Ummm... isn't the adjuster screw on the pushrod end of the rocker?  If so, as long as there is enough adjustment in the screw to compensate for the removed material, the rocker geometry should stay exactly the same.
I have already accounted for this in a conversation with Delta.
I had a torque grind applied to my cam, which takes approx .030" off the cam lobe.
In my removing .030" off my head/block surface, I have minimal adjustments to be made to my valvetrain ;)
My biggest monster is going to be the intake. Which may be getting cut down to fit with some custom piping, or I may just make a custom manifold.
But thank you for the reminder :)
Also, on break in, I already have break in oil in mind. I'll be switching to Schaffer's once Its all broken in and happy.
Twitch
I'm worried about airflow.
I may end up filing off the edges of the intake when I bolt it up so it flows better, if I have to oval the holes.
Twitch
  • 2 weeks later...
no ned to oval the inlet to head holes, unless you have an oval hole drill :) - just a larger diameter round drill bit in each hole both ends, makes a big difference
I'm going to oval them with a same sized drill bit as the hole, just grinding out the side that needs more space. That way I only have one plane to worry about when remounting rather than multiple.
Twitch
PS: Or I may just build a custom intake using my old manifold.
I just received the late 1986-1994 EA71 pistons, see pics.
The design seems not much different than the early EA71 pistons.
  • 3 weeks later...
Fascinating topic..  Added to might try to pull this off someday list.
The dealer said is same piston for ea71 and ea81 all ea71 all ea81s ex turbo cars a'm rebiulding a ea 81 for airplane and when resarching pistons this is what we were told by dealer. I oppted for the 94 ea82 pistons as they have the strongest ring lands. And reliability is key.
hey twitch I have an EA71 engine I am trying to get rid of.If you still need pistions I could pull it apart and pull the pistons+rings for $50 for all four pistons.
MIles? Condition? Known problems with the engine (eg: overheating, burning oil, etc)?
Twitch
Unfortunately I don't know anything about them.The engine was in the back of a vehicle I bought.I had the heads off because I was going to change the headgaskets and run it but while it was apart I managed to loose about 1/2 the bolts/nuts/and pushrods,I suppose that is what I get for building an engine in my driveway.So I decided just to get an EJ22 and not even worry about the EA71. The bores looked very good when I had the heads.I tilted the engine up on the side and poured a bit of oil into the bores and it seemed to stay on top of the pistons so it shouldn't leak much.
  • 11 years later...
There is NO difference between ea71 and ea81 pistons I have pulled down both motors the Pistons are the EXACTLY same dimensions, gudgeon pin dimensions etc are the same. Both pistons are 92mm. EA71 has a 60mm stroke and a 111mm Conrod centre to centre , and the ea81 a 67mm stroke and a 117mm conrod c-c. The engine block of the ea71 is 345mm and the ea81 370mm. EA82 pistons are 92mm and compatible with both ea71 and ea81 motors. EA82 Turbo pistons are 92mm and they are recessed on the top and are a non event in a non turbo motor. To get the extra performance from Turbo ea82 pistons the engine has to be fitted with a turbo.
Edited by gazza01
More information
