September 20, 201312 yr Dear Readers, I need some advice -- my airbag sensor in my 2005 Subaru Outback passenger seat went bag -- i can't get an annual sticker until I get it fixed... Don't want to buy a new seat, too expensive... Any advice much appreciated! Thank you! Brian briancunger@gmail.com
September 20, 201312 yr Are you sure something didnt get crammed under the seat and damage the wiring? Is it the occupant sensor or the side airbag inflator that has gone bad?
September 20, 201312 yr Author Thank you for your very fast reply! My mechanic checked out the wiring and said that the sensor inside the seat has gone bad. He called the dealer and they said that the sensors cannot be re calibrated, that a new seat is the repair... I suppose I could try to find a used seat but not easy... It's the occupant sensor in the passenger front seat... Maybe worth to complain to Subaru? Complain to Consumer Prod board -- shouldn't an airbag safety item be guaranteed for life? Grateful for any advice...
September 20, 201312 yr I'm not entirely sure how those work but I would first try unplugging the sensor and plugging it back in. More often than not a bad connection causes problems like this. From looking at the FSM it looks like you will only be able to unplug the main power seat harness connector. The connectors for the sensors and occupant detection control module are not accessible. Still worth a shot though since there could be a poor power or ground connection in the main harness plug. You might be able to find a used seat through Car-part.com. It's very expensive to shop a seat though, and shipping a seat with an airbag in it presents other problems. Its an explosive, which is highly regulated, which means it costs quite a bit more. But you may be able to find a place close enough that you can just drive over to pick up the seat. Edited September 20, 201312 yr by Fairtax4me
September 20, 201312 yr Thank you for your very fast reply! My mechanic checked out the wiring and said that the sensor inside the seat has gone bad. He called the dealer and they said that the sensors cannot be re calibrated, that a new seat is the repair... I suppose I could try to find a used seat but not easy... It's the occupant sensor in the passenger front seat... Maybe worth to complain to Subaru? Complain to Consumer Prod board -- shouldn't an airbag safety item be guaranteed for life? Grateful for any advice... Bull.. Subaru dealers use a calibrated lead weight to calibrate the old seats. From what a service tech told me it was not uncommon to have them fall out of calibration.. The 2012+ models use a hydration sensor and do not go off weight and cannot be calibrated.
September 20, 201312 yr Author Thanks All, amazing diversity of replies and ideas. If I may, i'll have the dealer read the code and come back for some more advice. Have a nice weekend!
September 20, 201312 yr Are you sure you want to have the dealer read the code? It could be expensive! Check around some of the parts "chain stores" like Autozone--they will often read codes for free. At any rate, get the code number--not just a verbal description--and post it here. Good luck.
September 20, 201312 yr Parts stores cannot read airbag system codes. They can only read emissions codes related to the ECU/PCM. Airbag codes (and in particular the occupant detection system codes) on this model can only be read with a high end scanner (Snap-On) or Subaru Select Monitor.
September 20, 201312 yr Makes sense to me! Thanks Fairtax. I guess I'm so old-fashioned that when I see "code" I automatically think OBD codes!
September 20, 201312 yr like larry pointed to - www.car-parts.com or ebay - the ebay vendors will ship anything. i've bought entire leather interiors with side impact air bags off of ebay and had them shipped. didn't cost that much and it was for a vehicle that was 7 years old at the time...same as yours right now. no way in a billion years i'd pay for a new seat from Subaru.
September 21, 201312 yr I had an air bag/seat belt issue and it turned out to be a defective overhead center console. Is that where you are getting the warning and is it intermittent? What was the indicator that you had a problem? Mine was an intermittent problem and was diagnosed by a Subaru tech as a courtesy.I just replaced the overhead map light console in my 08 OB.I wonder how many of these have failed and if SOA would provide thenumber. The problem being that if that light is ON, the airbag system isOFF. So this does become a safety issue and not just a blinky lightproblem.Anyway, replacement was fairly simple.Pry off light lens, 4 Phillips screws, 2 electrical connections. Replace with new unit and the problem has not returned since. I have read that others experimented with re solderingthe components on the small circuit board but I didn't try it myself.I paid about $100 for the console and of course SOA "never heard of aproblem" with these units, even though I snagged one at my localdealership that was already on order for another customer. Edited September 21, 201312 yr by brus brother
October 3, 201312 yr Author Hello All, I originated this question/forum and I am amazed by the generous advice I recieved -- thank you for taking your time to help! I went to the dealer who read the codes -- my mechanic is a dope, it was a sensor in the overhead console not the passenger seat -- I must bow to Subaru Master's post, he was spot on. Dealer will fix for $385, not as bad a a new seat for $2000+... Thanks again!
October 4, 201312 yr Author Hello All, I originated this question/forum and I am amazed by the generous advice I recieved -- thank you for taking your time to help! I went to the dealer who read the codes -- my mechanic is a dope, it was a sensor in the overhead console not the passenger seat -- I must bow to Subaru Master's post, he was spot on. Dealer will fix for $385, not as bad a a new seat for $2000+... Thanks again!
October 6, 201312 yr Hello All, I originated this question/forum and I am amazed by the generous advice I recieved -- thank you for taking your time to help! I went to the dealer who read the codes -- my mechanic is a dope, it was a sensor in the overhead console not the passenger seat -- I must bow to Subaru Master's post, he was spot on. Dealer will fix for $385, not as bad a a new seat for $2000+... Thanks again! a new seat for $2000+... it would be a very cold day, before I would ever spend that much for a new seat. That is insanity. I hope $2000+ is a typo error. If not, I would go on line to find a good used one for a lot less money.
October 8, 201312 yr Author Yes, I agree... I just found out the fix is the $385 I mentioned (overhead map console) + a clock spring? -- anyway about $500... yes, the dealer told my mech over the phone a new seat was $2000... I would have bought a used one if needed... thanks!
