I am looking for more power down low below 1000 RPM
Yes.  Tested it again yesterday at Johnson's Creek in the mud and snow. Much fun.
  • Replies 112
  • Views 14.6k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • EA81 it scott!!!!   Jeff
  • Divorced t-case.
  • Probably nothing as he seems to have built a quite capable rig with the appropriate precautions installed to avoid overheating or damaging his equipment.   The Manual vs Automatic debate is a waste
Posted Images
Hydrogen and Oxygen gasses separated through electrolysis.
The problem has always been creating enough of it to actually be worth using.  If you want to produce alot of it, you need alot of electricity, which bogs down the ALT, so claims to improved effieciency are inconsistant.  It's always variable depending on the type of system you run.
You can produce it at home, and then capture and transfer it.....but hydrogen is hard to contain, and very explosive too......
I have yet to see an HHO system with any real world practical returns.
While serving in the Submarine Navy  I ran the Oxygen generators,
Pure water plus Potassium plus high voltage equals Hydrogen gas and Oxygen Gas.
H20 + K + V = H2 O2
although the machines were each bigger than an L series.
but potassium REACTS explosively with water.
Im still looking for a 2.2 and was doing some reading looks like you wana find 1999+ 2.2 heads for lower torque rpm's and better air flow 0n a 1996- engine to keep non interfaces engine
http://en.m.wikipedia.org/wiki/Subaru_EJ_engine
99 heads won't fit any of the older intake setups.....so you'd need the 99 2.2 harness ECU as well.
Just get a 90-96 EJ22
isn't H2 O2 Hydrogen Peroxide?
I think he meant H2  and O2 seperately.
not H2O2
  • 3 weeks later...
Well, this isn't quite ready for mass use, and is probably way out of budget to get them to fit it to your engine, but if you eliminated the camshafts, you could probably get a lot more torque at low rpm, without sacrificing your high rpm.  This video is part of a series done touring the Swedish car maker, Koenigsegg.  This particular one, the explain one of their technologies they are working on for the future, called the Cargen Free Valve System.  Probably not practical yet, but something to get your brain going.
What vid?
It displays as part of the post for me.  Here's a link:
http://youtu.be/Bch5B23_pu0
Edited by Dj7291993
I really don't know if it hurts the engine, but retarding the timing will give you CRAZY torque down low. Back when I didn't know anything about timing, I had mine set pretty much right on top dead center. You could let it idle up 10 degree hills no problem. Ran like crap in any other situation though.
not H2O2
Thank you.
  • 2 weeks later...
On I was reading on another thread on here about injector improvements from other engines good read if a bit hard to follow
