AWD J3wman Posted December 23, 2013 Share Posted December 23, 2013 (edited) So I'm in the process of doing a Shakotan build on my GL-10, Its 4WD and the lowest I've been able to get it so far is about an inch lower than my CRX's stock ride height. I feel like I'm fighting Goliath here trying to get this down, does anyone have documentation of a 4WD Loyale or GL slammed? I've personally seen it on a FWD one, it was scraping the frame, but never on a 4WD so far.My setup currently is:XT front struts stock wagon springsStock struts in back with CRX coilover sleeves in back all the way down.I have a pic of where it sits now. What am I doing wrong? lol I got a winter and a blown head gasket so I got time to sort this stance out. I also have some NB Miata rear struts I can pop in but need to get another set of coilover sleeves that will fit on them. Edited December 23, 2013 by AWD J3wman Quote Link to comment Share on other sites More sharing options...
Kevint143 Posted December 23, 2013 Share Posted December 23, 2013 have you tried getting shorter springs? My brat is pretty low but the rears torsion bar I clocked it as low as I could and then put a shock out of a chevy luv in the rear. the front I fitted 2wd front suspension out of a gl-10 with some slight modifications. 1979 Subaru BRAT by Kevin Talley, on Flickr If I can get my first gen this low I am sure you can get yours lower. Quote Link to comment Share on other sites More sharing options...
AWD J3wman Posted December 23, 2013 Author Share Posted December 23, 2013 Yeah, my CRX coilover springs are less than half the height of a stock one. Quote Link to comment Share on other sites More sharing options...
86 Wonder Wedge Posted December 23, 2013 Share Posted December 23, 2013 Have you inverted the rear strut mount bracket? I've read its worth about an inch. and I gather you're not a fan of cutting springs? Even if you experiment with the stocks, OEM replacements are still available. Quote Link to comment Share on other sites More sharing options...
Kevint143 Posted December 23, 2013 Share Posted December 23, 2013 cut the springs they can't ride any worse than stock ones do ha! Quote Link to comment Share on other sites More sharing options...
wagonist Posted December 23, 2013 Share Posted December 23, 2013 I'm trying to get mine lower also. But as the interior & other parts are not currently fitted, it looks like it's got a lift kit Got some lowered springs on XT parts to try. Get a spare set of springs & start cutting them to see what happens. I'd also suggest getting some coilovers made. Suspension shops here will custom fit the threaded sleeve to existing struts/shocks. That way you can keep some spring height, but still wind it down. I think I'll end up going this route. Quote Link to comment Share on other sites More sharing options...
ShakotanBoogie Posted December 23, 2013 Share Posted December 23, 2013 You can really get down there. Technically you don't even need coilovers in the rear, any 2.5" diameter circle track spring at about 8" will get you tucked just right on the stock shocks. Flipping the rear mount with the BFH clearance method gets you an inch or so while retaining your travel so that is worth doing...I am going to run GC Impreza front lowering springs and generic rears on my XT. Should have it ready soon (wheel bearings coming first). There is always the old thread for pics... http://www.ultimatesubaru.org/forum/topic/66334-any-one-have-any-pictures-of-lowered-ea82s 2 Quote Link to comment Share on other sites More sharing options...
AWD J3wman Posted December 24, 2013 Author Share Posted December 24, 2013 You can really get down there. Technically you don't even need coilovers in the rear, any 2.5" diameter circle track spring at about 8" will get you tucked just right on the stock shocks. Flipping the rear mount with the BFH clearance method gets you an inch or so while retaining your travel so that is worth doing...I am going to run GC Impreza front lowering springs and generic rears on my XT. Should have it ready soon (wheel bearings coming first). There is always the old thread for pics... http://www.ultimatesubaru.org/forum/topic/66334-any-one-have-any-pictures-of-lowered-ea82s Flipping the rear mount with a Big effing hammer? how? I used coilovers off a CRX so I dont need to cut, mine are already about 8" tall, including the last .25" on the sleeve. Taking out the sleeve will net me another 1.25" drop, what all do you got for your set up? Quote Link to comment Share on other sites More sharing options...
86 Wonder Wedge Posted December 24, 2013 Share Posted December 24, 2013 IIRC, you only have to use the BFH on the XT, everyone else has the clearence. Quote Link to comment Share on other sites More sharing options...
AWD J3wman Posted December 24, 2013 Author Share Posted December 24, 2013 WHERE DO YOU USE A BFH!? Quote Link to comment Share on other sites More sharing options...
el_freddo Posted December 27, 2013 Share Posted December 27, 2013 You flip the rear strut mount, then use a BFH IF the strut fouls any of the guard with the top mount inverted. I'm sure you'll get more than an inch out of inverting that mount. You'll need spring compressors to do the job...CheersBennie Quote Link to comment Share on other sites More sharing options...
ivans imports Posted December 27, 2013 Share Posted December 27, 2013 4.44 gears is lowest LoL Just to mess with you Quote Link to comment Share on other sites More sharing options...
AWD J3wman Posted December 27, 2013 Author Share Posted December 27, 2013 Oh okay thanks, that makes sense. I can probably figure it out myself but if anyone has a picture of the mounts so I know im doing it right thatd be awesome. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted December 27, 2013 Share Posted December 27, 2013 Flipping the mount you need clearance directly above the shock. Where the shock nut/washer/rubber are on top. I Used a big punch hit with the hammer to keep the bashing centered where it was needed. There is a hole in the layers of sheet stamping right where it needs to be just punch that up 1/2" or so. Quote Link to comment Share on other sites More sharing options...
AWD J3wman Posted December 30, 2013 Author Share Posted December 30, 2013 okay that makes sense, id still love a pic if anyone has one available Quote Link to comment Share on other sites More sharing options...
AWD J3wman Posted April 23, 2014 Author Share Posted April 23, 2014 No pics of an inverted strut mount? Quote Link to comment Share on other sites More sharing options...
SmashedGlass Posted April 23, 2014 Share Posted April 23, 2014 Take item #12 in the following picture off the strut assembly, flip it, reinstall on strut. Simple. Use spring/strut compressors, obviously. Quote Link to comment Share on other sites More sharing options...
elgigante Posted April 23, 2014 Share Posted April 23, 2014 Just out of curiosity, would the same concept with sleeve overs and etc work on a 4x4 gl wagon? Quote Link to comment Share on other sites More sharing options...
AWD J3wman Posted April 23, 2014 Author Share Posted April 23, 2014 Take item #12 in the following picture off the strut assembly, flip it, reinstall on strut. Simple. Use spring/strut compressors, obviously. Thanks! Just out of curiosity, would the same concept with sleeve overs and etc work on a 4x4 gl wagon? yes I am doing that. Mine is a GL-10 AWD Turbo with rear disc brakes. Are you trying to raise or lower it? Quote Link to comment Share on other sites More sharing options...
elgigante Posted April 23, 2014 Share Posted April 23, 2014 Lower it. Quote Link to comment Share on other sites More sharing options...
elgigante Posted April 23, 2014 Share Posted April 23, 2014 Im going to figyre out how to mount s13 coil overs on it. Quote Link to comment Share on other sites More sharing options...
subaru_styles Posted April 24, 2014 Share Posted April 24, 2014 thats my coupe..tucking 60 series tires on the 13's Quote Link to comment Share on other sites More sharing options...
Brutality Boy Posted September 22, 2014 Share Posted September 22, 2014 When you go low enough in the rear with the re clock on the spring plate do you have a tow in problem? One that can be corrected with like an extended spring plate like on an aircooled volkswagen? Quote Link to comment Share on other sites More sharing options...
