April 8, 201412 yr You got it completly done???. Hmmmm?? Or just the idea is there along with a huge hole in the fender!
April 8, 201412 yr You got it completly done???. Hmmmm?? Or just the idea is there along with a huge hole in the fender! looks done to me!
April 9, 201412 yr Thats gonna get borked on tree.. You'd think but I've seen lots of them like that and they are fine. The wheel sticks out way further so you'll hit the tree with the wheel before the snorkel.
April 9, 201412 yr There's are two tree I like to squeeze through at our local spot down the road and I haven't hit my snorkel yet. Tires actually drive up the base of the trees and the body drops down after so I think he's good.
April 10, 201412 yr my snorkel is the least of my worries, its my first real wheeling tripso I think some body damage is on the menu while I become spatially aware..
April 10, 201412 yr I'm not too concerned about hitting it on a tree. But I guess the 26th will be the judge of that.
April 10, 201412 yr I think you mean stump. Ah the joys of learning a new vehicle on unfamilar terrain.
April 10, 201412 yr Jeff... what was the trail we came down the last time near the end? Need to do that one again... More fun than Ron's Run.
April 10, 201412 yr Jeff... what was the trail we came down the last time near the end? Need to do that one again... More fun than Ron's Run. Upper Mainline?
April 11, 201412 yr Hey Nick and Marcus, are you guys still rolling open diffs? If so we need to get you welded up for walker. You at least want an Lsd. Walker is a big step up from Tahuya, there is no easy option on most of the trails. Just sayin Jesse
April 12, 201412 yr Author Upper has become pretty gnarly............ I think that's on the list for the run!!!!!! Jeff
April 12, 201412 yr Author you can run open but you'll end up beating your car pretty bad doing it. Jeff
April 15, 201411 yr Yeah Jeff is right. I had a hard time on one of the short connector trails with a broken diff stub. Weld up and it will make the trip that much more fun. Instead of stuff like this.
April 15, 201411 yr Get a spare and weld it up, then you can just swap them out when you get to the trail
April 15, 201411 yr That or weld it up and pull an axle for street driving.You can drive on the street with it welded and both axles in but it stresses parts a bit more than they should. Gloyale believes that driving on the street with a welded rear diff and both axles in results in a stub axle breaking on the trail.
April 15, 201411 yr Iv run a welded diff befor with axels in just wasnt my cup o tea... i didnt wanna buy a spare diff unlrss it was a good lsd so i could do that but its proving hard to find one... trying to put money in where counts.. rear sub needs reinforced front blocks need reinforced... no skid plate... the list just gets longer... im not sure ima make this one im not tryin to trash the car on purpose cuz i wasnt ready for somthin... but dont get me wrong i wanna go.
April 16, 201411 yr I'll start looking for a spare diff to weld up. Anyone got an extra I can buy? I'm more concerned about my tires.
