May 23, 201411 yr I have a recently bought 2006 Subaru Impreza and today it started leaking a thick green slime like fluid around the CV boot. Also, it is a manual and when the clutch is disengaged there is a screeching metal grinding sound that just started since I noticed the leak.
May 23, 201411 yr I guess CV boot grease could have a greenish tint, It's usually black or very dark grey color. Can you tell of the screechy sound is coming from the axle? Screechy sound occurs when clutch disengaged (pedal down) would be the release bearing.
May 23, 201411 yr Author I cant tell where the screech is coming from but I have heard from multiple people that it could be the throw out bearing
May 23, 201411 yr may be two separate issues. Clutches don't throw any greem slime ever...........so maybe clutch problems...........how does it drive?? Only thing green I can think of is antifreeze, but it is never thick. CV joint is always black stinky grease found under the car.
May 24, 201411 yr inner CVJ boot? could be Redline Lightweight Shockproof I guess, it is 'smurf blood' blue. when fresh. have you check the trans fluid level?
