EA82 rear axle stub bolts stuck!
So I've been giving those bolts a good whack with a hammer and a lot of pb blaster but they wanna stay right where there at. I've been using a 8mm socket but I'm worried I may strip the heads so I'm gonna grab an e10 torx if it doesn't wanna budge soon. Any tips on getting these things out without destroying my stubs? Thanks guys!
I'm not sure what bolts are you talking about. Removing the rear axle takes punching out the spring pins, the lock ring, axle nut and you gotta pound the stub out of the bearing...but there aren't any bolts in the stub right?
I think he means separating the stub from the axle itself. There's no bolts. It's just pressed in, and pulls out. If it doesn't come out, it's seized with rust.
Oh no I'm talking about the axle stubs that are in the rear differential. The stubs have to be removed to get the carrier out of the diff.
they are on there pretty darn tight, however ive yet to strip one with my 8mm deepwell socket
Get a long piece of tube and pulllll
Well after a lot of hammering, a bit of heat, and a lot of pb blaster, one of the heads stripped. Now I'm left swearing a storm and stumped.
Grab a 6 sided socket, you'll never have that problem again
It was a six sided socket.
Holy crap....
Only idea I have is to cut a slot in it, perfectly across, put some sheet metal or a screwdriver in, and twist.
