84 4wd Touring wagon
Engine was taken to Engine reconditioners.measured the crank,and bits.
Pistons were within measured tolerances,so life still left in them,so
didn't go for rebore and new pistons.So EA81 engine housings bore will
be honed,new rings STD standard size.Main bearings crank ground to new bearing
size of .010 for conrod bearings STD size.
of crankshaft after petrol washed blowen with compressed air,bearing
surfaces reoiled.
  • Replies 102
  • Views 19.7k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Hi to all just bought this 1984 4WD Touring wagon,have kinda of liked them as learnt to drive in one,my father had a plain wagon as company car,when he worked at Motor Holdings Ltd in New Zealand.This
  • Sweet! I saw this on TradeMe and was really hoping someone would pick it up, there's precious few EA81s on the road here anymore, let alone touring wagons (probably my favourite). One of my neighbours
  • The turbo wagon is dead unfortunately. Terminal rust in the firewall and windscreen pillars/corners, and the paint had gone through on the roof and bonnet and was starting to rust badly. Also had a lo
Posted Images
Cylinder heads skimmed.
Engine reconditioners total costs $270.00 NZ Dollars.
New bearings installed.All engine parts cleaned,
surfaces oiled,a mechanic was on hand,parts put back together
as Subaru factory service manual.
Main Bearings in one side.
Crankshaft in, and camshaft.These bits came from spare engine and conrods.
original camshafts and followers badly worn so thrown away.
All other engine parts reused.
valves were lapped at home with valve paste,
while engine was away.
Freshed up engine in car.radiator sent away to be checked ,pressured checked.
  • 1 month later...
Beautiful work. Great to see it coming together! Hope you can get it registered on the original black plates
licensing ,rego on hold black plates all good.
Engine does not idle good, took it to someone to test,air leak somewhere.
3000rpm air leak disappears,spindle on carb possible?, running
lean a little, they adjusted it,drive it good to go,might have take back for
further look at it.
  • 2 months later...
Do I put 4WD and touring wagon stripes on,will get price for it.
Need a steering rack, and fan shroud,
thanks for looking.
  • 2 weeks later...
Definitely needs some touring wagon decals! Love it.
  • 5 months later...
Graphics on,pick up some brat/brumby rims paint them off white.
I like the mag wheels you had on earlier, hope you kept them ... :/
Found these in pick a part rusty.
tyres taken off and dumped.
had some lacquer paint off white lying around.added a
little of yellow to it.dabbed a bit of paint on the rim
where the tyre hides the paint , the colour close to old
colour,as didn't want to paint them pure white.
The wheels rims will get road grime, brake dust over in time.
