March 30, 201511 yr any thoughts on this would be great gave this 1999 legacy 2.2 to my mom a few years ago she lives in phoenix, az this past summer she said as long as she parks it in the shade it starts fine if she parks it in the sun it will not start , has to be jumped and then will start and run fine swears if she parks it in the shade it has no problems.... it has zero problems in the winter, starts fine every time wondering if there is a relay, etc close to the top of the motor that might be affected more by the heat build up... the car will go to subiworx in phoenix as soon as it acts up again , but thought i might see if there were any suggestions here thank you
March 31, 201511 yr Heat does wierd things to cars, and in Az it can be dramatic. Subarus are known for having the solenoid contacts go bad with time, and this is about the right age. I would also check the condition of the battery and clean the battery terminals. I am assuming here there is no cranking when she turns the key?
March 31, 201511 yr I agree....most likely a battery contact. the ring around the battery terminal will expand in heat and contract in cooler temperatures giving it contact when cool and open circuit when hot. if not, other possibilities: coil pack could be going bad too. when they get hot they stop working. they are located on top of the engine and will absorb the heat transferred up from the intake manifold and right under the hood. if the vehicle is a dark color this adds to the heat absorption.other things to check would be the fuel delivery system and make sure all is tight as fuel will evaporate out of any leaking areas including leaky injectors causing it to be out of fuel or possibly flooding itself... if this is the case turn the key on without starting it and you will hear the fuel pump prime up for a few seconds. turn the key off and do it again..then try to start it holding the accelerator all the way down to open the intake and allow it to air out.....hope this can help and good luck
March 31, 201511 yr how old is the battery? I'd expect a battery may only last 2.5 to 3 years in much of AZ. but more details about the no start could help. Is there any sound, does it crank and sputter....w'ever
March 31, 201511 yr Author unfortunately i am not driving it so hard to get really detailed info my understanding is it acts like the battery is dead but then will start fine whne jumped battery is only a year old and supposedly they checked the wires/connections etc last summer when it was doing this where is the solenoid located? and interesting thoughts about the coil pack too
March 31, 201511 yr I was going to skip hot soak coil issues as they would be hotter in Az with the car running then sit parked in the sun. http://thumbs3.ebaystatic.com/d/l225/m/m0XR9ZZdUj2NmkY1NM3Dyqg.jpg and http://s214.photobucket.com/user/1320fastback/media/DSC00847.jpg.html
March 31, 201511 yr well, if there is a click, but no cranking, I'd definitely consider new plunger/contacts in the solenoid (on the starter) as an experiment, sometime when the contacts are intermittent, a car will start after you whack the starter. Use a piece of 2x4. Try a tap first, then a 'bunt' then, a 'single'. if you literally hear nothing, could be some kinda ignition or neutral safety switch. Though jumping 'shouldn't' help with those failures.
March 31, 201511 yr For giggles next time it happens have her put the car in Neutral then turn the key As Texan said show her where the starter is and tell her to wack it as hard as she can (she wont hurt it)
April 1, 201511 yr Author lol, unless the starter is on the top of the motor somewhere, very easy to see etc my mother is not going to whack it with anything she is not at all mechanically inclined i considered the starter issues also but does seem weird she says as soon as it is jumped it starts if i had it i would just start throwing parts at it, but she is not like that hopefully subiworx will be able to replicate the problem and figure it out i will reply back with the solution once it starts acting up and they see it, wont be long, getting hot here
April 1, 201511 yr Actually it will get worse with time. A jumpstart has much more amperage then a single battery and can jump past bad contacts, for now.
April 1, 201511 yr Author yes on the battery and knowing my mother she probably bought a cheap one lol interesting about the jump starting having more amps etc will see what the shop comes up with, just wanted to have some ideas or if it was something easy and cheap i could change out myself may not be quite hot enough here for it to mess up, but wont be long
April 1, 201511 yr Bad battery. Heat is the worst for batteries, contrary to popular belief that cold is bad. Heat is worse.
April 2, 201511 yr Author just saw my mother and she said the sometimes the car is fine and then sometimes she drives it somewhere in the summer, parks it for an hour or two and then comes back out and the battery is dead somtimes it will jump and sometimes it is so dead they have to take it to autozone and charge it for a few hours it has doen this with two different batteries it seems to be an intermittent high/fast drain what could be getting stuck and drining a battery that fast? coil??
April 2, 201511 yr Thats hard to do from this distance, diagnose it from afar. First we need to get away from autozone. It may not be draining as much as keeping up with the load on some days. Someone needs to test the charging system first, properly.
April 2, 201511 yr Author i agree, dont use autozone for anything the car is 2 hours away from me, so hard to do much with it i plan to go with the car monday to get the timing belt replaced and discuss all this with the shop, no reason they cannot check charging system etc will fill everyone in on what fixes the problem
April 2, 201510 yr Since everyone here has already given good advice (my bet is on the battery too), I'm just going to leave this here: AZ is the pit of hell, with all due respect to where you live. If one lives in the pit of hell, one needs to expect that bad things are going to happen. Emily
April 2, 201510 yr I don't know how old your mother is. But I know mine is getting up there and regularly does things like leaving door slightly open, or keys in/on.
April 2, 201510 yr people have accidentally hit the parking switch on top of the steering column (virgin switch) on many occasions. Might be easy to overlook too. any way, sounds like checking for parasitic drain would be a good idea. consider also, a battery that has had multiple complete drain events will have limited life span. Edited April 2, 201510 yr by 1 Lucky Texan
April 2, 201510 yr Author all good advice, will go over a lot of this with the shop next week i agree emily, not overly fond of az even though i live here, but this heat is hell on the cars and it does not help that my older mother is not good about taking car of cars, does not know much about them and does only short city trips with it, taking a toll on the car have a lot of stuff to go over on it with subi worx next week, anyone ever used that shop? it has good google reviews....
April 2, 201510 yr Lots of short tri[s eh? I would start by going over the charging system with a fine tooth comb. Get a good name brand battery. Decrease tehe Maint inervals on the car and do check the parking light switch on the steering column. Thats the #1 source of a battery killer.
