February 9, 20179 yr It looks as though CCR has changed hands?? Does anyone know to what extent things have changed or restructured as far as management and/or experienced builders goes? I currently have a JDM 2.0L SOHC (non-turbo) in my 2k OBW and its absolutely dreadful on power. I use my Subaru like a truck not a grocery-getter and this things not cutting it anymore. I'd like to drop a 2.5 back in when I can afford it. Way back when I was on this forum a lot more, I remember CCR having lots of positive reviews and even EMILY chiming in a time or two to add some very knowledgeable advice and comments. If I go this route I'd like to know CCR is still as reputable (if not more so) as they were before the restructure. Edited February 9, 20179 yr by 211
February 13, 20179 yr I don't know about CCR's restructuring, but I build all the engines for my shop personally. I can build one however you like and we are a lot closer than Colorado. Typically we build them using the newer heat treated turbo crankshafts and tri-metal race bearings, etc. There are other options besides a full rebuild also. Subaru themselves offers a reman short block assembly thats reasonable or we could source a used engine and just do piston rings, skirt knurling, etc. Hit us up on Facebook if you would like a quote: https://m.facebook.com/superiorsoobie/ GD
February 13, 20179 yr Author I don't have FB but I'm interested in service of some sort.What I have is a 2.0L SOHC and I want a 2.5 back. For core purposes is the 2.0 useless as a return core for a 2.5?
February 13, 20179 yr Glad to hear from you again Rick, how are you? Good! Business is insane. Apparently a shop that doesn't screw you car up worse than when it came in is hard to find. The stories I could tell from the last few years. Ho-lee-chit. GD
February 13, 20179 yr I don't have FB but I'm interested in service of some sort. What I have is a 2.0L SOHC and I want a 2.5 back. For core purposes is the 2.0 useless as a return core for a 2.5? I would not need a core. We would just get you a used engine. I often just buy ones that came from front end collisions and have bent valves, etc. It's not a problem to swap out the valves if you are already doing head gaskets, rings, etc. Or we could buy a reman short block from Subaru. They are about $2150. I have lots of extra heads no problem there. If you want a custom build with heat treated crank and race bearings, etc then we could either buy new case halves from Subaru or I can have a used set reconditioned, etc. You can also email me at: rick@superiorsoobie.com Or call the shop: 503-880-4084 GD Edited February 13, 20179 yr by GeneralDisorder
February 14, 20179 yr Totally different shop in a new location. I use to take used 2.5 DOHC cores up the Rick and Emily at the old CCR. I always enjoyed doing business with them over the years. Great source of engines and information. The new owner seems good, it's just not the same CCR. I assume they are good, time will tell.
October 29, 20214 yr Anyone rebuilding ea82 for 84" Subaru gl wagon 4x4 fwd.. ?? Cars in new Mexico.. cost?. Like one in pict...
October 29, 20214 yr Scott , I hope you mean EA81 and not EA82 Its your business of course but man it would hurt me if you stuck an OHC engine in there. If you do , go EJ not EA. Best of luck with it. Enjoy ! No experience with CCR other than Shawn worked there once upon a time and yeah we played “Willy and the Poor Boys” until we wore the grooves down.
October 29, 20214 yr I had the new CCR do two engine rebuilds for me for cars I was fixing and selling. I was happy with both and never had any questions back from the new owners.
October 31, 20214 yr On 10/28/2021 at 6:35 PM, Scott84 said: Anyone rebuilding ea82 for 84" Subaru gl wagon 4x4 fwd.. ?? Cars in new Mexico.. cost?. Like one in pict... Can't really get the parts to rebuild the EA's anymore. Best bet is used. GD
