December 16, 20178 yr Here is another use of the Ej251 with phase 1 Heads (Frankenmotor) in a 1991 Miata called the miataone.com. Edited December 16, 20178 yr by hirsch58
December 18, 20178 yr Man, I bet that think is spunky when you hit the gas. I've often daydreamed of taking a crunched impreza and making a cool AWD roadster out of an old Fiat, Opel, etc. Edited December 18, 20178 yr by AdventureSubaru
December 20, 20178 yr Is there a link to the build? I'm wondering how the torque tube was installed on a Subaru engine
December 20, 20178 yr Author Take a look at this website: www.miataone.com , has a real nice bracket the places the motor in right place in the engine bay
December 20, 20178 yr I wonder how long the transmission will last being used as a rwd rather than awd. It looks like they just plug the openings for the front axles.
December 20, 20178 yr Author Silverhelme, The Transmission is not just plugged. It's converted properly to a rear wheel drive only trans.The front differential is removed and the center diff housing is then welded to transfer all torque to the Miata rear wheels. This the same method that is used to driffed subaru's.
December 20, 20178 yr Very interesting, and I'm sure it'll be a fun car. Yea, those transfer gears typically don't hold up well to being the sole output, but the light weight and relatively low power levels here will help. Might want to start budgeting to upgrade those. Custom driveshaft, I assume? Seems like a pretty niche market. Someone with the time and skill to assemble an engine, and notch the crossmember and framerail, but wants some bolt-on brackets? Probably a great candidate for a BRZ transmission, or Bill's bellhousing to a Toyota RWD transmission.
