es81 rear bumpstop removal?
Anyone removed these? Looks like rubber is bonded to a flat but about 70 mm. Would expect something like an M10 stud
There is a stud embedded in the rubber, IIRC.  I've never had luck removing them (granted, I haven't tried very hard) but I would thing you could slit the rubber to expose the stud then turn it out with some vice-grips.
I should have added I do not want to destroy, just ' tinker'
Thanks for reply
Good luck without destroying them at this age!
Have a new set on hand if you're going to try and remove your ones.
Cheers
Bennie
They turn out. Or at least when they will allow you to turn them out. I’ve got a set of new for 70’s which are probably the same as 80’s
