May 26, 20196 yr Thanks i never taken my shify to any car meet i will have to consider it. I did go to the Aurora junkyard but there was nothing of value i seen on that 69. Its been there for a while many parts were missing.
May 29, 20196 yr On 5/23/2019 at 6:53 PM, el_freddo said: No mechanical clutch fan - just a direct drive. It requires a different alternator bracket with it and this doesn’t work with AC. Cheers Bennie This will work on a hatchback?
May 30, 20196 yr 7 hours ago, Unknownjeremiah said: This will work on a hatchback? If it’s got an EA81 it will. Just make sure you put it on the EA81 and not on the hatchback Cheers Bennie
May 30, 20196 yr 13 hours ago, el_freddo said: If it’s got an EA81 it will. Just make sure you put it on the EA81 and not on the hatchback Cheers Bennie Which vehicles would I be able to find those on? Neither my brat or hatch had a direct drive. Both have the electric fan.
May 30, 20196 yr 42 minutes ago, Unknownjeremiah said: Which vehicles would I be able to find those on? Neither my brat or hatch had a direct drive. Both have the electric fan. Any EA81 models without AC. Look for base model vehicles - sedans and flat top wagons typically. Cheers Bennie
May 31, 20196 yr Shoot, I'll sell you the old clutch'ed mechanical fan off my EA81T if you would like that?
May 31, 20196 yr 18 hours ago, el_freddo said: Any EA81 models without AC. Look for base model vehicles - sedans and flat top wagons typically. Cheers Bennie Not quite. My 84 turbo has no AC and no direct drive fan. Maybe you meant WITH AC?
May 31, 20196 yr 2 hours ago, carfreak85 said: Shoot, I'll sell you the old clutch'ed mechanical fan off my EA81T if you would like that? Where does that mount to? Send a picture of it?
May 31, 20196 yr I’m debating about buying this fan motor and hoping it’s the right one from the Subaru parts store in Tacoma.
May 31, 20196 yr 6 hours ago, naru2 said: Not quite. My 84 turbo has no AC and no direct drive fan. Maybe you meant WITH AC? No, definitely without AC. @carfreak85 - The turbo one won’t fit as that is based on the EA82 setup. The EA81 doesn’t have the ability to bolt anything to the water pump pulley. I’m starting to think this fan was an Australian only thing - but I find that hard to believe. ^ This is what I’m talking about. Mover here, if you’ve got AC fitted this fan is removed for a second electric fan that’s run by the AC wiring loom. Here’s a pic of the stock electric fan with the AC (top unit): If you can’t find a mechanical fan, I’d be using all of that available space for a larger thermo fan or two smaller units. I’ve got 2x 12 inch on my L series from memory - these cool the EJ just fine, so cooling the little EA81 would be a breeze. Cheers Bennie Edited May 31, 20196 yr by el_freddo
June 1, 20196 yr All the fans I can find seem to be mounted through the core and made of plastic. I would love to have both fans on there. But like I said, I might just have to spend all that money on a new fan motor from Subaru.
June 1, 20196 yr 22 hours ago, Unknownjeremiah said: I’m debating about buying this fan motor and hoping it’s the right one from the Subaru parts store in Tacoma. Why decide based on hope?Fitment info is readily available.This fan motor is not for a brat. Make Body & Trim Engine & Transmission 1987 Subaru DL Base 1.8L H4 - Gas 1986 Subaru DL Base 1.8L H4 - Gas 1985 Subaru DL Base 1.8L H4 - Gas 1987 Subaru GL Base, Turbo 1.8L H4 - Gas 1986 Subaru GL Base, Turbo 1.8L H4 - Gas 1985 Subaru GL Base, Turbo 1.8L H4 - Gas 1987 Subaru GL-10 Base, Turbo 1.8L H4 - Gas 1986 Subaru GL-10 Base, Turbo 1.8L H4 - Gas 1985 Subaru GL-10 Base, Turbo 1.8L H4 - Gas 1987 Subaru RX Turbo 1.8L H4 - Gas 1986 Subaru RX Turbo 1.8L H4 - Gas 1985 Subaru RX Turbo 1.8L H4 - Gas 1986 Subaru XT DL, GL, GL-10 Turbo 1.8L H4 - Gas Get one that fits https://www.ebay.com/itm/Subaru-Brat-Brumby-284-MV-1978-1994-EA81-Engine-Cooling-Fan-Housing/233234834318?hash=item364de1238e:g:ueoAAOSwSeVaKo7- I`m sure there are more closer to home.
June 1, 20196 yr 10 minutes ago, naru2 said: Why decide based on hope?Fitment info is readily available.This fan motor is not for a brat. Make Body & Trim Engine & Transmission 1987 Subaru DL Base 1.8L H4 - Gas 1986 Subaru DL Base 1.8L H4 - Gas 1985 Subaru DL Base 1.8L H4 - Gas 1987 Subaru GL Base, Turbo 1.8L H4 - Gas 1986 Subaru GL Base, Turbo 1.8L H4 - Gas 1985 Subaru GL Base, Turbo 1.8L H4 - Gas 1987 Subaru GL-10 Base, Turbo 1.8L H4 - Gas 1986 Subaru GL-10 Base, Turbo 1.8L H4 - Gas 1985 Subaru GL-10 Base, Turbo 1.8L H4 - Gas 1987 Subaru RX Turbo 1.8L H4 - Gas 1986 Subaru RX Turbo 1.8L H4 - Gas 1985 Subaru RX Turbo 1.8L H4 - Gas 1986 Subaru XT DL, GL, GL-10 Turbo 1.8L H4 - Gas Get one that fits https://www.ebay.com/itm/Subaru-Brat-Brumby-284-MV-1978-1994-EA81-Engine-Cooling-Fan-Housing/233234834318?hash=item364de1238e:g:ueoAAOSwSeVaKo7- I`m sure there are more closer to home. I am not working on a brat, working on a hatchback. But also thanks.
