August 18, 20196 yr I have tried search functions without success on this topic. I have the EJ and it's box crudely sitting in the bay. I have fitted up a pooey old aluminium radiator originally sourced via eBay. Recently felt sorry for the fella in the US region saying he got one from Australia. Get rid of the cap that comes with it and also the washer on the drain tap These are heavy duty cooling capacity so about fatter. With radiator in place, engines rear mounting not sorted - there is a maximum 45 mm clearance between radiator core and crank pulley. I'd like 5-8 mm final clearance for torsional movement so some skinny fans engine side will be needed. The radiator pipe outlets are 30 mm. The EJ top hose pipe is 38.7 mm. Anyone found in -hose adapter/ reducers for part of this task? Any hoses to butcher for sections suggested? Given the masses out there with an EJ in their EA81 bodies there must be so many who have done this and know just what to do and explain easy to someone who is decades behind these pioneers I am thinking most use std EA81 radiators or is the BRZ the way to go now? I recall some have radiator shops braze in new fittings to radiator at least for the lower hose. The top hose looks a crazy angle to deal with. Any suggestions and links, pics and diagrams welcome and appreciated
August 18, 20196 yr Author I may have even suggested this following idea before somewhere ....it is an adaptor to allow for an inline sensor to be screwed into the 1/8" tapered hole in the side - eBay of course. I got them for emergency hose repair This is 30 mm size. 30 is max diameter at the rib not where hose clamp goes it is about 28 mm If I can entice a friend to turn it's odd hex shape down to 38.7 mm then cut in half - got 2 somethings to play with The crude cast inside diameter of my EJ20 outlet for top hose is about 31 mm
August 18, 20196 yr Jono, you’ve pretty much nailed all the ways to do this from what I’ve tried/done myself. I’m currently running with a set of home made adaptors and use a cut down of the two EJ radiator hoses and one EA hose to make the setup work. It will be very similar to the EA81 setup - but I’m also running a lift so I have a bit more length to play with. I like your idea of turning that adaptor down. That’d be a neat solution. A custom pipe would be awesome but I don’t know of anyone who does this. Cheers Bennie
August 18, 20196 yr Author It is called pattern making I believe. You take a long time making a custom top and bottom hose from paper, then cardboard , then metal then add a joiner each end to give some flex. Show us yer hoses post coming up Those adapters are $7 posted so think Tambox will be getting a surprise in the mail direct from eBay Edited August 18, 20196 yr by Steptoe
August 18, 20196 yr Author While musing on this topic, BRZ /86 radiator us out of budget The dimensions for 2012 model are 650. 350.42 700.390.42 are the outside measures of the alloy unit made for EA81 Assuming radiator hoses are ~ 39 mm ID
August 18, 20196 yr Author Hmmmm...I probably will forget. That adaptor from the studios of Steptoe is actually a project on hold. It has a 5/8" hose barb for lower hose of EA, with long hose to a remote fill coolant reservoir out of an Astra .... and that is where it stopped when I found standard Brumby radiator on the EA82 is excellent, far superior to EA82 single core
August 21, 20196 yr Hey Fellas, Gotta admit its been something like 12 months since I have been online here and my Brumby conversion hasn't moved much further along then it was last time... Lack of progress aside I can give some advice, for mine I used the standard Brass/Copper radiator bolted up as normal. I am not running power steering or air conditioning at this time so my cooling fan is on the engine side of the radiator, towards the drivers side. There's not much clearance between it and the crank pulley but I think it will be ok. It has been a hell of a long time since I bought my hoses so I don't know what the part numbers were now however they were made by Mackay and they were a heavy canvas lined hose that was bendable and with different sized ends, 32mm and 38mm if I remember right. Here's a link to a PDF from the Mackay website that has the hoses I am talking about. https://docs.wixstatic.com/ugd/17eaaa_6a4ab92c8a7847c6905c997db207e796.pdf If I get a chance this weekend I might actually do the 80km trek to the shed where its pulled apart and grab some photos for you.
August 21, 20196 yr Author Oh that sort of double size hose in Oz will be handy You pics will be appreciated, meanwhile I had better cruise Mackay's hose catalogue I like two electric fans on all my Subies. My current daily is Brumby with a fan mounted front side, RHS of car. Took a lot of work to make it fit in. Just an old freebie from an Astra . German made Bosch from memory. The idea of fans in front frees up radiator space and removal with, well only one fan between engine and radiator
September 6, 20196 yr Author This custom modified adapter could butt up at either end , radiator or engine, or mid hose. It was made from same as red thing in photos
September 6, 20196 yr Where did you find that Jono? I’d be keen for a set of these to replace my no-so-good-rushed-I’ll-change-them-later units! Cheers Bennie
September 6, 20196 yr Author Haven Industries in Clayton turned it up from my idea, improved on it with their own specialist touch. Sounds like this sort of thing can be found in the US, maybe by Gates? Started off by purchasing within Oz and having the seller post direct, supplied and delivered cheaper than I could post one from my place! Edited September 6, 20196 yr by Steptoe
September 7, 20196 yr I found hoses off the shelf that had the 2 differing ends, and also the 6" rise I needed for my lift. I had pics of the part #s on my old Photobucket account.....unfortunately I'm not sure I can acess it anymore. I need to dig them up somehow, those hoses are 11years old.......Time to change soon. For other EJ swaps, with no lift, I simply used flex 16" and 18" hoses with 1-1/4" on one end and 1-1/2" on the other. I carry a 24" spare for use in the wheeler. for now.
September 7, 20196 yr Author A bad experience with a flex hose in the 80s put me off them for life. Maybe we just had a bad one? I sort of view them the same as a temporary spare and only if you must. Maybe I need to change my views of them Also feel we have big companies choosing what they bring in to Australia to retail. You choice you Americans have is mind blowing. Fancy getting an AC service kit at Walmart Might be time to get some accurate lengths need and import a few personally if this cherished adaptor won't work
September 8, 20196 yr Neat! I have the factory ea82 radiator on my swapped wagon with some cheapo no name fan on the outside. I found the fan at the junkyard in a first gen legacy. As I was finally finishing the ej install 3 years ago, (took me 8 months!) I ordered a piece very similar to that one, but made of silicone. then two pieces of flexy hose with the spring inside and some beating and coercing and my coolant circuit may be ugly, but she stays cool enough! in fact I didn't change a thing on her, same pieces from about 20,000 miles ago. I was reading an old hot rod magazine (2005) and a new part for $6 was a strip of metal with a spring that goes around the outside of a hose...you bend and trim as needed. genius! but i never seen this in real life however.
September 8, 20196 yr Author That cool thing is the Unicoil, invented , I believe, by a fella last name Bozic in Perth, Western Australia. They were marketed in a bizarre way, seemed to only be sold in pairs of either 1/2" or 5/8" and a metre of heater hose to suit. Not sure workshops wanted to buy heater hose they already had at bulk wholesale prices. We bought them for the jigger Fantastic device I believe was licenced or something to Gates who made them available individually. My local Gates supplier put me in a panic saying there were out of production, NLA. Moving right along, finding that a typical line from them for stuff they can't supply. Seem to be marketed again as or by Unicoil . Best Subaru application I found is for the bent coolant hose at the back of the EA82T along with silicone heater hose. If anyone finds a general hose adapter for these two sizes feel free to put in a link Edited September 9, 20196 yr by Steptoe Edit silly !
