October 3, 20196 yr I just picked up a 86 XT turbo awd with a rusted through rear crossmember, I've had no luck finding a replacement, does anyone know if any other models used the same crossmember or know of one that would fit?
October 3, 20196 yr L series 4wd sedan (rare!) or wagon will be a direct replacement. Put your swing arms on for the swaybar and rear discs. The L series 2wd will fit but needs the front diff mount welded on. Cheers Bennie
October 4, 20196 yr 6 hours ago, idosubaru said: Any EA82. Loyale, RX, XT, XT6, GL wagons Holes in the XT6 mounts will be too large for the 4cy XT arms. He needs parts from a 4cyl something. Wagon, Sedan, or 3 door, or another XT
October 9, 20196 yr On 10/3/2019 at 6:15 PM, Inclement said: I just picked up a 86 XT turbo awd with a rusted through rear crossmember, I've had no luck finding a replacement, does anyone know if any other models used the same crossmember or know of one that would fit? If you have problems finding one close, there is an XT in a yard about 3hrs from me.
