Ej22 Idle oddity/issue
Hey team,
I recently changed my oil and redid wiring for my crank angle sensor
my car is performing and idling better than it was before, but it periodically has a rougher idle (more vibrations when idling) - usually, it is remedied by flipping the car into neutral and then back into drive which I find really odd. Once in a while, the idle goes a tad lower but usually, it's around the 700-800 rpm mark which is good.
any ideas what could be causing this? maybe a dirty IAC? maybe spark plugs/spark plug wires? I'm at a loss!!
Thanks in advance!
Edit - My car is a 1991 Subaru liberty/legacy with 161'000km on the clock (100'040 miles)
Edited by Auz23
I dunno, wondering if examining the plugs might give a clue? maybe a cylinder is misfiring and a plug would appear different than the other 3 ?
I'll give this a check and let you know !
It could be a sticky IACV.
Also a good time to check for any stored codes, this might give a clue as to what could be part of the issue.
Cheers
Bennie
