somick Posted December 8, 2019 Share Posted December 8, 2019 The vehicle is 2010 Forester with 106000 miles. The YouTuber brianmobil1 mentioned that the top of the tensioner rod must be smooth. Mine is warn out. It is not leaking oil and I was going to reuse it. Should I replace it? Thanks for looking, Sam Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 8, 2019 Share Posted December 8, 2019 That looks like more than normal. Replace if paying labor, consider replacing if not. I’d wonder what caused the wear, weak tensioner...? There’s hardly a reason to not replace it anyway. I mean I get it - it’s a $100 but drop in the bucket for the value you’re getting for another 100k. If you’re not paying labor and want to reuse it, inspect it after 30k-50k. Removing covers and belt alone and reinstalling can be done in under and hour. Might even be able to inspect without removing the belt? Tight area but maybe you could get a measurement to compare? I’ve done it in 45 minutes without hurrying. No big deal. 1 Quote Link to comment Share on other sites More sharing options...
ocei77 Posted December 9, 2019 Share Posted December 9, 2019 Get rid of it. T belt and accessory change is 100K or 8 years IIRC. You can get a quality kit with tensioner for @$150. O. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 9, 2019 Share Posted December 9, 2019 Replace every timing belt. GD Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted December 9, 2019 Share Posted December 9, 2019 (edited) wonder what the rod the end of the piston rod rests on in the adapter looks like? Edited December 9, 2019 by 1 Lucky Texan Quote Link to comment Share on other sites More sharing options...
somick Posted December 9, 2019 Author Share Posted December 9, 2019 13 hours ago, 1 Lucky Texan said: wonder what the rod the end of the piston rod rests on in the adapter looks like? I was thinking the same way but did not get to it yet. Quote Link to comment Share on other sites More sharing options...
