October 9, 20205 yr I have a 88 xt6 and don't know where the flasher relay is. What kind of relay do I buy? The hazards and turn signal lights turn on and stay on and don't flash and it screeches at you. Guessing it's under the dash. Has somebody done a tutorial?
October 9, 20205 yr There’s a rack of relays above the fuse box down below the drivers left foot. Check those? All the relays there are the same, swap one one to test. Or it’s under the ask tray, I’m forgetting.
October 9, 20205 yr Author 1 hour ago, idosubaru said: There’s a rack of relays above the fuse box down below the drivers left foot. Check those? All the relays there are the same, swap one one to test. Or it’s under the ask tray, I’m forgetting. The fuse box is just fuses and is fine. Underneath everything is just wiring. The ashtray thing has a blue box.
October 9, 20205 yr Author 8 minutes ago, lrgvanman said: Usually mounted on assembly to left of brakelight switch. Where would that be?
October 10, 20205 yr Author 5 hours ago, idosubaru said: There’s a rack of relays above the fuse box down below the drivers left foot. Check those? All the relays there are the same, swap one one to test. Or it’s under the ask tray, I’m forgetting. This thing?
October 10, 20205 yr 12 minutes ago, xXArchusXx said: This thing? Yes I think that’s it. The photo is so close I can’t see any reference points but that appears to be a stack of relays. it’s down in the drivers footwell looking up. I’m not positive the relay you need is there but I think it might be. how positive are you that the relay is the problem? It’s fairly common for people to ask where a part is only to find out later that it wasn’t the issue.
October 10, 20205 yr Author 14 minutes ago, idosubaru said: Yes I think that’s it. The photo is so close I can’t see any reference points but that appears to be a stack of relays. it’s down in the drivers footwell looking up. I’m not positive the relay you need is there but I think it might be. how positive are you that the relay is the problem? It’s fairly common for people to ask where a part is only to find out later that it wasn’t the issue. The lights turn on when u use turn signal doesn't flash and the hazards don't flash. It is 32 year old car after all. Where can I get a diagram for the fuses?
October 10, 20205 yr Author 18 hours ago, john in KY said: Just start disconnecting them one at the time. Did that. The hazards still turned on.
October 10, 20205 yr Author 18 hours ago, idosubaru said: Yes I think that’s it. The photo is so close I can’t see any reference points but that appears to be a stack of relays. it’s down in the drivers footwell looking up. I’m not positive the relay you need is there but I think it might be. how positive are you that the relay is the problem? It’s fairly common for people to ask where a part is only to find out later that it wasn’t the issue. The pic is to the left of the brake pedal USDM. What else could it be? Unplugged each thing one at a time and the hazards still worked.
October 12, 20205 yr On 10/10/2020 at 3:43 PM, xXArchusXx said: The pic is to the left of the brake pedal USDM. What else could it be? Unplugged each thing one at a time and the hazards still worked. “the hazzards still worked”. I’m not being a troll - trying to clear up exactly what to look for. The hazzard (and blinker) lights are coming on but not flashing? If that’s the case, I would check the bulbs and sockets for corrosion. Even a working bulb can rarely cause issues with wiring, dash lights, and control button/switch functionality as it changes the current and resistance of the circuit. I’m traveling and can’t turn on my laptop to look up the hazzard wiring (relay or timer?) specifics.
October 19, 20205 yr Author On 10/12/2020 at 10:26 AM, idosubaru said: “the hazzards still worked”. I’m not being a troll - trying to clear up exactly what to look for. The hazzard (and blinker) lights are coming on but not flashing? If that’s the case, I would check the bulbs and sockets for corrosion. Even a working bulb can rarely cause issues with wiring, dash lights, and control button/switch functionality as it changes the current and resistance of the circuit. I’m traveling and can’t turn on my laptop to look up the hazzard wiring (relay or timer?) specifics. VID_20201010_123851.mp4
February 5, 20233 yr Old thread but I have been dealing with this EXACT problem on my 1989 Subaru XT6. The turn signals come on but they do not flash. It's just a solid light inside and outside of the car. However, you can hear it sounding like a really fast flash, inside the car. It's almost a constant sound rather than a tick, tick (Sounds turn signals make when they are flashing on and off). Here's a link to a video I made it on Facebook (if the link works), under Kevin Thomas XT6 Turn Signal problem
February 5, 20233 yr i think the system does what you describe when one or more of the bulbs ( outside ones) has an issue, bad connection or burned filament. i'd start with a close check of them first, especially if it started suddenly, and had been working ok.
February 7, 20233 yr You didn't change to any LED bulbs did you? Also this info seems to agree with Ruparts suggestion about low current draw from bad bulbs, wiring or contacts. https://ricksfreeautorepairadvice.com/subaru-turn-signal-blinking-fast/
