December 27, 20205 yr Has anyone tried ATV rims on the 4x140 Subarus. CAN-AM bolt pattern is 4x137, it dosent seem 3mm would make that much difference.
December 28, 20205 yr Just no. 3mm is a lot when it comes to bolt patterns. This idea is all kinds of wrong. Cheers Bennie
December 28, 20205 yr Author Im not talking about smashing them together and running them as is. Im looking to see how much of a problem it would be to have them properly clearanced. I will check it out and post what i find. Just curious and in no way recommended something sketchy or dangerous. I don't think an idea can be wrong, just the application of the idea. Stay tuned, it may not lead to anything, but i will look into it.
December 29, 20205 yr clearing the brakes is the next concern, im curious if it would work, but i would think using 4 15" spare rims would be more practical with skinny tractor tires
December 29, 20205 yr Author Im not talking about small 4wheelers here. Im talking about the large side by sides that are larger and heavier than Brats. They have a huge selection of 14in custom rims and DOT aproved tires.
December 29, 20205 yr Darn. Have to wonder why their "engineers" chose 137 mm for the bolt pattern. Why not "round" off to a whole number?
December 29, 20205 yr get an adapter? http://tireshopsupplies.com/index.php?main_page=product_info&cPath=41_302&products_id=4797 https://www.uswheeladapters.com/wheel-adapters/ Edited December 29, 20205 yr by 1 Lucky Texan
December 29, 20205 yr Author Thats an awesome deal. You can order them thicker too, to get them to clear in the rear.
December 30, 20205 yr Can you get these rims without the bolt pattern drilled before purchase? Then have a shop drill to 4x140. Interesting you have ATVs that are heavier than the Brat! Cheers Bennie
December 30, 20205 yr you know, ive seen wheels before that had a universal lug pattern, and it was slotted, very strange, and i couldnt see why that wouldnt work on these too
December 30, 20205 yr Author All my neighbors have big UTVs. We all curious about the brat. Im at work in the gulf of Mexico and i wont be back until the 6th.
December 30, 20205 yr And the Brat weighs in at what, 2000-2200 pounds? (I’m having to convert in my head as I think they’re about 1050kg from memory). Cheers Bennie
