August 4, 200421 yr ea82 PS pump mounted to ea81 motor? can it be done? talking pump only.... I got a pump and bracket with hardware just sitting here. Wanna find out?
August 4, 200421 yr Yes - I know it can be done. Mudrat has done it before, so I know it's possible. Besides that the EA81T's had em, so it makes sense..... GD
August 4, 200421 yr Yeah the EA81T used the same or very similar ps pump but there maybe a difference in the bracket.
August 6, 200421 yr The pump is the same (as so many things are) between the EA81T and the EA82, I've actually got a new EA82 pump going on my freshly rebuilt EA81T. The only prolem with a standard EA81 is that you need to either come up with a different alternator bracket, or modify the origonal one, and or make a new base plate for the 82's pump because thw holes aren't right, one or the other, I can't remember right now without fishing through the dark for parts to line up. I can have an accurate answer in the morning though.
