gazza01 Posted May 1, 2025 Share Posted May 1, 2025 (edited) I scored an Subaru EA81 engine that has been bored out to take 0.50mm Pistons just need to know what size rings I should be using. Edited May 4, 2025 by gazza01 no edit Link to comment Share on other sites More sharing options...
Turbone Posted May 5, 2025 Share Posted May 5, 2025 Contact these folks and ask if the have .50 rings. Also, you can look thru all the other vendors on ebay to see if someone sells the set. I tend to steer away from DNJ parts, As they are cheap chineseum stuff, but I've had good luck with Hastings and NPR https://www.ebay.com/itm/286535946018?fits=Year%3A1984|Engine+-+Liter_Display%3A1.8L|Trim%3ABase+Hardtop+2-Door|Model%3AGL|Make%3ASubaru|Submodel%3ABase|Engine%3A1.8L+1781CC+H4+GAS+OHV+Naturally+Aspirated&_skw=Engine+Piston+Ring+Set&itmmeta=01JTGGCDK5QCYY56G3JP27C2G5&hash=item42b6df8f22:g:GRMAAOSwGV1n8-L7&itmprp=enc%3AAQAKAAABIFkggFvd1GGDu0w3yXCmi1dVY6P5gatqhuRHuVG4ciQApiO91CmKZ1GKhjuDRTL1uR8hyiSb5sbsItgmuoKoBQlCzg23eI%2BhpPrJpzKKCP4lOjPOopLM3kluSYyR%2Fc76VCR13ECk%2B7T6Iy3QfGbavPNaOIG1rLJ6m3eAYuK%2FEWNMUZLPY%2Bo%2Bud6v3Uzwmo58K%2Fg964pFpDXHq7E1XZOljK2MhX8HT5DvSWlpcB9UOcbDjoG0ai3Pr8rb1KaI%2B%2FbGScHm1YJZ326VlfMnXDQFMyh77DAvU1C%2BkXpEYnGJVNmYjI3XcOORaUDrio5A%2BiGczM9gGwQUSRqfW3TEXNW3jqgRq3cfxaRbszs1W4rijv825AENgRfUdu6o5Pr7mVfSUw%3D%3D|tkp%3ABk9SR-DZsZDUZQ Link to comment Share on other sites More sharing options...
moosens Posted May 5, 2025 Share Posted May 5, 2025 That’s maximum as I know it. And I can’t recall seeing 50 over. Not many folks have bothered at that point. I cannot recall anyone with a 50 over EA anything. Good luck with it. Link to comment Share on other sites More sharing options...
czny Posted May 5, 2025 Share Posted May 5, 2025 (edited) 92.50 mm, either 2.0mm 1st & 2nd or 1.2mm 1st & 2nd rings, depending on engine/piston. https://hastingspistonrings.com/catalogs-cross-reference/ https://hastingspistonrings.com/wp-content/uploads/2023/05/asian-catalog-americas.pdf https://www.ebay.com/itm/187161728886?fits=Make%3ASubaru&_skw=subaru+92.50+mm+EA81+piston+rings&itmmeta=01JTH36YHWEVD0QXGV0YXQQ7AS&hash=item2b93b55776:g:bS0AAeSw-8loBnk~&itmprp=enc%3AAQAKAAAA4FkggFvd1GGDu0w3yXCmi1ds6hQQs5C0Aavw5a6pUKCItZ201Ll3mNujqNg%2FsDD%2FLkBJ7WFKlwnHz4MCZCGppX%2FDPCDO2CTW%2Fvzc4HYFSx3w9SyT4GZCR6X%2BQAOqWhGGlpjyupNBUSt2bDQiHwVVQrWC8j3PomzHL%2FC3cd7lS0b6r1WQN%2BzytOPdLZcBBAbGI79artDEqCIFjPgS20GvkOHTQBPMLEpKJg8wrV0ut6%2FgSomiZDBl%2BETktnc2BjmLNBg0pz0GA6%2FPT4uRkWL1yd3ExzklURJ2K4Rak9MQpInT|tkp%3ABk9SR47pm6PUZQ Contact seller importengineparts on fleabay for NPR rings. YMMV Edited May 5, 2025 by czny Link to comment Share on other sites More sharing options...
el_freddo Posted May 14, 2025 Share Posted May 14, 2025 If you really love the EA82 you could have the engine sleeved. 50 thou over seems a lot. I thought 40 thou was as far as they went with new rings and pistons for the EA82. I could be wrong, I only ever rebuilt one before I really learned about them. Cheers Bennie Link to comment Share on other sites More sharing options...
