Quickest possible question regarding 2001 3.0 H6
I’ll put my bet in for interference. But chain timing rather than rubber belt cam timing, so something needs to be pretty catastrophic for valves to hit pistons in this engine - anything is possible though!
True. On the flip side I’d rather a known fact that it’s NON-interference than a bet that it is.
I’m 99% sure the last non interference engine Subaru produced was the gen1 EJ22E. The Gen2 EJ22E used roller rockers that helped bump the compression ratio for better power but the downside was the engine became an interference engine.
Since the H6 is chain driven, interference or non-interference shouldn’t be an issue unless you’re trying to settle a pissing competition between you and a mate.
Edited by el_freddo
No, this is a real-world problem.  Car died very suddenly on the highway (en route home from the glass shop with a brand-new windshield after a windstorm+tree took it out.  Such is my life these days.) and the symptoms are:  Cranks, but sounds different, like less stuff than normal is turning; cam position sensor error.  That it's turning at all seems like somewhat good news, as that suggests I don't have a piston wedged against a valve, though it doesn't mean there wasn't a hit.  Hence the question.
So my first guess is a thrown chain (the EZ30 has two).  But since then (last week), winter has set in here for real - it's subzero, we're under a foot of snow, and the car is not (yet) in my (unheated) garage, where I'll have to pull the 64-bolt timing cover in order to confirm my suspicion.  And first I've gotta bolt a winch onto the far garage wall so I can pull it in...
How many miles on it? And what’s the service interval for the timing chain?
Easiest way to determine whether your suspicions are on the right track is to do a compression test. If there’s a cam timing issue I’d expect one bank to be far lower than the other.
If a chain let go, I’d expect some sort of grinding/crunching noise of the broken chain and spinning components when cranking the engine over.
If the chain is intact, it could be a tensioner let the timing chain skip some teeth.
Either way, if this is the issue, I see some very un fun times ahead.
Last thought: check the cam sensor and rule out that there are any issues there. Cam timing sensor is used for spark and injector pulses from my understanding. This could change the engine tone/noise when trying to start.
All the best
I have not seen anything officially saying one way or the other. But I would also bet interference. Even the 2.2 went interference in '97ish. That said, I see the FSM has a specific note to use caution installing the timing belt on a 2.5, as incorrect timing could cause piston to valve contact, and there is no such note in the 3.0 timing chain section....
I don't think I've seen or known of one break a chain. I've heard timing chain noise several times before due to damaged/worn guides and/or tensioners. Not that it isn't possible, but I'd be highly skeptical that it just broke without making a bunch of noise.
What Cam sensor code? P0340 is for cam sensor circuit, indicating a wiring issue or failed sensor, P0341 indicates good signal but out of time. I've had engines attempting to start with bad sensor data sound strange while cranking.
If it broke on the highway, the valves are already bent. It'll turn over nicely now.
Before you touch those cover bolts, definitely do a compression test. If it fails that, I would drop the exhaust and look up the ports at the valves you can see (IIRC the front valves are hard to see through the single exhaust ports), and then crank it again to see if you can hear the compression blowing out the exhaust.
If you have cylinders with no compression, but the offending valve cover and check to see if the buckets move freely and smoothly. While a stuck valve won't prevent a bucket from moving all the way out, there won't be any spring pressure on it.
I believe you can see the bank 2 chain through the oil filler cap.
Drop the oil into a clean pan and look for debris. Cut open the filter for the same. I would expect to see considerable metal in the oil if the chain has been failing. Maybe even drop the lower pan and look for bigger pieces of debris.
I have an 01 H6 with no compression on cylinder 3. It all blows out the exhaust. I removed the valve cover and can move the valve buckets/springs freely with a prybar, resistance and movement feels identical on all 6 exhaust valves on that side (I believe if the valve wasn't closing all the way, the spring/bucket would not return all the way). It will still run, just super rough. I believe it to be a burned valve. And I will almost certainly swap in a used engine before I bother pulling everything apart enough to replace a valve. I have a couple known good high mileage engines. Or maybe try to get a JDM, although those are a lot less common/cheap than they used to be.
  • 2 weeks later...
Original engine? 01's and some 02's were notorious for timing chain noise.  I believe due to tensioners and they have jumped timing before.  I've seen failed tensioners and guides, never a failed chain though I'm sure anything is possible.
  • 1 month later...
(A few months later, 'cause I had to clean out enough of the garage to get the car in over the pit and buy a Warn Pullzall (110VAC comealong - got a smokin' deal on it) to pull it in, then wait for a break in the weather, since the garage is unheated...)
But now the cover's off and I've confirmed that the driver's side chain broke.  Since the driver's side chain drives the passenger side chain, what sounded to me like just the crank and no cams cranking was in fact just the crank and no cams cranking.  It's not clear whether the chain broke on its own, or whether it was caused by a guide fragmenting, and there are some loose plastic bits in there.  Doesn't matter much, timing kit is en route from Rock.
As for whether anything got hit, jury's still out.  It's so damn tight along the sides of the engine that I'm not sure I can get a compression gauge in there.  But I'm also replacing the steering rack while it's over the pit, so I'll be dropping the exhaust and can take a peek up at the valves.  Otherwise, I'll just see how things behave once the new kit is installed.  I do have an untested junkyard motor on the shelf (bought as a spare a couple of years ago), so I can draw upon that if necessary.
But I'll see how it goes over the next few days.
Airbox and washer reservoir out, pitchstopper loose, remove motor mount nut on one side, lift the engine and it will tilt up. Easy access to spark plugs/compression test.
Yeah, that's a lot of crap (including the engine) to move - when I get to that point.
At the moment I'm just pissed at the bait+switch that DHL is pulling on me - again - over my shipment from Rock.  UPS said it'll be here next Tuesday for a reasonable price.  DHL said that for five bucks more they'd have it here tomorrow (Thursday).  Tracking now says next Tuesday, and I strongly doubt they won't screw that up, because we're rural and just past the edge of their delivery area (by, like, a mile) so I have no idea how or where (let alone when) I'll get it.  I'm an idiot, because I knew better.  I'm Charlie Brown running to kick the ball - again.
Edited by jonathan909
How are you guys still arguing over whether an engine is interferential or not?
EVERY SUBARU ENGINE AFTER 1997 is interferential. EVERY.ONE.
Geez, I've been gone a few years and you guys are still arguing this point? 🙄
We lost non-interferential in return for a lousy 5Mph power gain.  Crap trade if you ask me.
No argument here, just asking the question.  And important to note that this is the 3 litre H6, not just another 2.5 .  If you haven't driven one, then you're going to have to trust me that regardless of whether it's interference or not, this motor kicks the 2.5's @$$ in a way I didn't expect (and we've owned more than half a dozen EJ25s (AT and MT, all NA of course, no turbos) in addition to a couple of EJ22s).  When it's all loaded up, towing a boat, and climbing a hill, it has the juice where the 2.5 struggled.
2 cylinders will do that!
The H6 mated to a manual is quite the animal - especially back when the H6 only came with auto from the factory early on. L
Thanks for your contribution?
It's not hard. 2 bolts for the washer reservoir, one hose clamp for the airbox, loosen the 2 bolts for the pitch stopper, one nut on the motor mount. Floor jack and a piece of wood and the spark plugs are super easy to get to.
Well, I don't think I'll be bothering with that step.  I sat down the other day to install the timing kit, and immediately discovered what broke that chain - a seized intake cam.  So in all likelyhood I'll just be pulling the motor and figuring it out from there.
  • 1 month later...
I've had two different cars with the EZ30 engine, a 1992 SVX and a 2001 LL Bean Outback. Man, I loved those cars!
