New to me 2001 outback 2.5 manual
Just wanted to see if there is anything specific I need to check on.
I'm going to do searches for any tsb's and other stuff but wanted any input you all might have on it.
153k has some ticking from the engine. Not sure if it is lifter or piston slap.
Runs good.
EDIT son took it out to show his brother how to drive a standard and muffler fell off.  LOL
Got one ordered.
Thanks
Hush
They’re fairly great. I have a small fleet of them now. 2002,2003,2003,2003 all Legacy or Legacy Outback.
In 2004 and after you’ll get the fly by wire deal so no more throttle cable. And if you do an engine swap there’s a little work around for the EGR is swapping against the 2000-02 with a 2003 or 2004.
You might never need that info since they generally run pretty well.
Oh the piston slap in one of ours. Mostly when cold then quiets down. That’s the “new” lifter noise. Lifters aren’t as loud as the EA engines.
Worse problem with driving these is just the usual - other drivers.
Lifts can rock if not adjusted regularly. I need to do ours as it sounds like an EA81.
EJ251: The only issue they have for daily driving is a touchy throttle between no throttle and very light throttle. I find this annoying and am yet to find a solution - not that I’m looking hard as I’m too busy driving it then when I’m not I’m doing other things…
If you have the leaking coolant crustiness on the outside of the head, replace head gaskets with the Multi Layer Steel (MLS) units from the STi - someone here knows the part number for these.
I replaced ours and zero issues for 200,000kms so far. Engine now done 515,000kms which we’re stoked about. Still pulls like a freight train through the rev range. Uses a little oil but I’m not worried about that.
