JLDT Posted August 25, 2004 Share Posted August 25, 2004 I am wondering if they ever made a high output oil pump for my car, and if they did, where can I get it? It is an 86 GL ea82 carbed . . . thanks Quote Link to comment Share on other sites More sharing options...
boing Posted August 25, 2004 Share Posted August 25, 2004 the stock oil pump is a high output pump and should do anything that the engine demands. they really engineered a good pump for your ea82! If your pump is reading below 25 pounds of running (not idleing) pressure , you might want to look for leaks. Quote Link to comment Share on other sites More sharing options...
JLDT Posted August 25, 2004 Author Share Posted August 25, 2004 I am pretty sure that it was reading above 25 driving, but about 0 idling - is that normal? What is normal for driving? Thanks Quote Link to comment Share on other sites More sharing options...
toybuilder Posted August 25, 2004 Share Posted August 25, 2004 Yes there is a high output pump available for your engine. Try this thread: http://www.ultimatesubaru.org/forum/showthread.php?t=6294&highlight=high+volume+oil+pump Quote Link to comment Share on other sites More sharing options...
lagwagon Posted August 26, 2004 Share Posted August 26, 2004 Thank you, Thank you , Thank you , Thank you, ect...... for that link. I knew the HV pumps exististed but I didn't know where to find them. Thanks ! Quote Link to comment Share on other sites More sharing options...
subiemech85 Posted August 26, 2004 Share Posted August 26, 2004 what kind of guage are you using?\how is your oil?? Quote Link to comment Share on other sites More sharing options...
JLDT Posted August 26, 2004 Author Share Posted August 26, 2004 Oil is fine, and the gauge is the one in the console of the car - I am not overly concerned about it, but I am going to have it torn down to a point where it is easy to replace the pump, so i thought I might as well replace it . . . and I have had to thicken my oil in the past so I wanted to know if I could get a High output. Toybuilder - I didn't see a pump for the Ea82 carbed engine on that list just the Ea81 - are they the same? Thanks for the info Quote Link to comment Share on other sites More sharing options...
toybuilder Posted August 26, 2004 Share Posted August 26, 2004 Toybuilder - I didn't see a pump for the Ea82 carbed engine on that list just the Ea81 - are they the same? Thanks for the info All EA82 engines use the same type of oil pump. The EA81 pump is different. Look at the list of pumps again. The information for the third item on that list must be incorrect, but notice that all of the part numbers are the same for EA82 engines. The EA82 pump listed will work with your carbed engine. Quote Link to comment Share on other sites More sharing options...
