mcbrat Posted September 11, 2004 Share Posted September 11, 2004 I highly recommend the swap over to the 82+ electronic disty/coil/alt I put a new 83 coil, and a disty/alt from a 83 Brat into my '80 GL 4x4 wagon with 1600. it runs awesome now. I was hitting 80-85 today no problems, and it would hold the 80 up the hills that normaly I would have sunk down to 60-65 on.... and the swap is easy... Quote Link to comment Share on other sites More sharing options...
SUBARU3 Posted September 12, 2004 Share Posted September 12, 2004 Can this be done with Gen 1s? Can you elaborate on the process? Todd Quote Link to comment Share on other sites More sharing options...
bajavwnsoobnut Posted September 12, 2004 Share Posted September 12, 2004 yes it can and it's a drop in instalation I have one on my ea-65 thats in the 76 right now Quote Link to comment Share on other sites More sharing options...
mcbrat Posted September 12, 2004 Author Share Posted September 12, 2004 remove Alt remove coil and IGN module cut the plug off the Ext VR, and use the wires to join the proper ones together as indicated in the first link below. (read the comments too) install int VR Alt Install the newer electronic disty, and be sure to use the newer disty's hold down plate. the ea71 distys had 2 vac lines attached. attach the one for advance to the disty, and plug the retard vac line. I studied up my wiring diagrams, and used the link below for reference for the alt/VR swap. http://www.ultimatesubaru.org/forum/article.php?a=14 http://www.ultimatesubaru.org/forum/showthread.php?t=20988 Quote Link to comment Share on other sites More sharing options...
bajavwnsoobnut Posted September 12, 2004 Share Posted September 12, 2004 Hey Mick you don't need to do the change over to the int VR to run a Electronic disty mine is running fine with the ext VR Quote Link to comment Share on other sites More sharing options...
mcbrat Posted September 12, 2004 Author Share Posted September 12, 2004 yeah, I know, but my alt/VR was toast too, so I just changed everything Hey Mick you don't need to do the change over to the int VR to run a Electronic disty mine is running fine with the ext VR Quote Link to comment Share on other sites More sharing options...
bajavwnsoobnut Posted September 12, 2004 Share Posted September 12, 2004 k just checking cause I was wondering why you were saying that but yeah just take out old and put in new and put the wires on the coil correctly same with the cap and there you go Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted September 12, 2004 Share Posted September 12, 2004 Hmmm... Swap the alternator eh? Can someone snap a picture of the external voltage regulator for me? I dont think I've seen one before. Some pics of what wires need to be cut etc. would be very helpful too. Quote Link to comment Share on other sites More sharing options...
Rockman Posted September 13, 2004 Share Posted September 13, 2004 Just curious but is there any advantage to replacing a alternator that uses an external voltage regulator with a alt with an internal? Its been awhile since I looked under the hood of my 79 wagon but I believe I have an ex reg that is located in between the battery and the coil or above the coil. I'm planning a complete 1600 rebuild sometime this year. Great info! Quote Link to comment Share on other sites More sharing options...
ShawnW Posted September 13, 2004 Share Posted September 13, 2004 Why: Mainly because the int VR types are more readily available in yards and parts stores and you could put the XT6 higher amp alternator on if you wanted to. Quote Link to comment Share on other sites More sharing options...
Rockman Posted September 14, 2004 Share Posted September 14, 2004 ah, I get it-higher amp translates to more appliances. Quote Link to comment Share on other sites More sharing options...
