carrier bearing mounting question....
because youd have to spend some time and make brackets and stuff.... and youd have to weld those in anyway.
on morganms, we didnt even use the spacers from the 3inch lift kit. just flipped it around, and welded her in!
its reely not that critical, and welding has worked well several times....unless your afraid of fire =]
I used a manure spreader bar, cut in 1/2, to fit, turned bearing so the tabs were down, drilled the holes for the bearing, then jacked the driveshaft to the floor so the bar made contact, marked where the holes should go for the 3/8" bolts, drilled the holes using a drill press, put bar back up, and used a BAD to drill through the body, NOTE!! the carpet must be pulled up, used fender washers, stuck bolts in from topside with fenderwashers down through body and bar, lockwasher, and nut total of 6 holes, and no $ :smile:
