LSD's: 3.7 or 3.9? replacing 3.9
Greetings,
My '89 GL Touring Wagon has a 3.9 rear diff and I'd like to add a LSD. It sounds like the 3.7 is far more common, can I swap with the 3.7 or do I need to find a 3.9?
Thanks...
hey i used to live near bend madress to be exact but back to topic if you where to put a 3.7 in you would have to change the tranny also. to get a 3.9 lsd i do believe you have to take the lsd out of a 3.7 and put it in a 3.9 case.
Find a 3.7 LSD and put your existing 3.9 gears in the LSD and you'll have it.
I think there are numerous write-ups on the how to details.
Good luck
Glenn
82 SubaruHummer---Welded diff
01 Forester---LSD
Thanks for the info! Great group!
Anyone have any links for write ups on how to do the swap?
try a search
I'm going to be in Sisters around Christmas, I can show you how if you'd like. I can bring the special tool for removing the stub axles. If you have everything all ready, the whole process takes less then an hour.
