Does a VLSD match the 3.9 Gen II Brat rear axles?
The local yard took out the VLSD on my recomendation.If it works for my Brat I'll see if I can get it.
Viscous.
From what I understand, all diffs up until 95-96 area will work, any R160 diff. When they switched to the axles without roll pins, that's the R180 diff.
It's not so much the diff that matters, it is the gears inside that make the difference. If it is a 3.90 VLSD then yes it will work, had one in Vickys car. Later, Tim
Viscous.
My 96 Impreza doesn't have roll pins in the axles. If you look at the VLSD, you'll see that it has stub axles that are held in with a 'C' clip, just like that later axles, not a bolt like the EA series cars. If you had a set of those stub axles, you could use any diff.
Thanks guys.It's been a while since I talked to a rally racer about all this.You just confirmed what he said.'91 Legacy Turbos w/manual 5spd....just like he told me.Thanks again everybody.
