November 27, 200421 yr what does it take to swap a front ea82 axle in to a ea81? given spline count is the same is there a writeup somewhere? no search luck
November 27, 200421 yr The spline count on the DOJ wouldn't be a problem as long as you do not use Turbo 5-speed axle. But there are a few other things you may run into. EA82 axles are longer, you might have to change the inner wheel bearing seal, you may have to use an EA82 hub.
November 27, 200421 yr Author 2 git r houm the parts car has a good reman ea82 axle and I want to put it ntha ea81 to drive it home 300+miles it's one of those "MilesFox" type of adventure
November 28, 200421 yr 2 git r houm the parts car has a good reman ea82 axle and I want to put it ntha ea81 to drive it home 300+miles it's one of those "MilesFox" type of adventure not worth the trouble.... with a longer axle, you'd need to make the control arm longer or move the mount out for it, plus it'll mess up your camber. I may have a core axle with torn up boots.....
November 28, 200421 yr BUT... in a pinch, you can rebuild an ea81 axle with parts from an ea82 axle, and vise versa! =] just mix and match the parts that fit. seriously, it works.
