NoahDL88 Posted January 20, 2005 Share Posted January 20, 2005 So once you get the T-case you have two perfectly good stub shafts that are spinning as you're driving, and could also be spinning with the car at a stand still in 2wd, so heres the theory, make them a PTO, air compressor? thats all, just wanted to get this in print before i forgot. Quote Link to comment Share on other sites More sharing options...
tailgatewagon Posted January 20, 2005 Share Posted January 20, 2005 so the pto would be spinning all the time. it would work if you had a clutch like on the ac that could be turned on and off so that your air compressor isnt running all the time since the the front drive shafts are spinning in 2wd adn 4wd. Quote Link to comment Share on other sites More sharing options...
ezapar Posted January 20, 2005 Share Posted January 20, 2005 So once you get the T-case you have two perfectly good stub shafts that are spinning as you're driving, and could also be spinning with the car at a stand still in 2wd, so heres the theory, make them a PTO, air compressor? thats all, just wanted to get this in print before i forgot. Lumpycam already beat you to it buddy. . . Quote Link to comment Share on other sites More sharing options...
RavenTBK Posted January 20, 2005 Share Posted January 20, 2005 Lumpycam already beat you to it buddy. . . Damn.. and thats a good idea too. Where his writeup? Quote Link to comment Share on other sites More sharing options...
Ross Posted January 20, 2005 Share Posted January 20, 2005 How about a pto winch? some serious dragging power! Quote Link to comment Share on other sites More sharing options...
monstaru Posted January 20, 2005 Share Posted January 20, 2005 that would be some gearing down for sure!shouldn't be too hard though Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted January 20, 2005 Share Posted January 20, 2005 IN theory with an older FWD/4WD gearbox, in FWD the only stubs that are spinning are the front, and the rest of the car would virtually be in neutral. So a clutch type winch would be sweet. But the front diff is open, so you'd have to deal with that somehow. -Brian Quote Link to comment Share on other sites More sharing options...
Scoobywagon Posted January 20, 2005 Share Posted January 20, 2005 Got this idea about a year ago and am currently trying to accumulate the parts. I'll use DOJ cups to attach a variable displacement hydraulic pump to each axle stub. These will be plumbed "in parallel" to each other and will run a military type hydraulic winch mounted at the vehicle's center of gravity. a roller fairlead will be mounted above it so that the center-mounted winch can pull the vehicle in any desired direction, to include straight up. Quote Link to comment Share on other sites More sharing options...
RavenTBK Posted January 20, 2005 Share Posted January 20, 2005 But the front diff is open, so you'd have to deal with that somehow. I thought of that same thing when I first read this thread. It can be easily solved by putting a couple of tack welds onto one stub to hold it still. Voila! Instant "locker". Maybe a lil piece of steel or something set up at an angle from the top of the stub down to the case. Something that can easily be removed and wouldnt fark up the seals there at the stub. It wouldnt take all that much pressure/strength to lock down one side.. Quote Link to comment Share on other sites More sharing options...
MorganM Posted January 20, 2005 Share Posted January 20, 2005 Lumpycam already beat you to it buddy. . . What does he have setup running off the stubs? Quote Link to comment Share on other sites More sharing options...
mudrat79 Posted January 20, 2005 Share Posted January 20, 2005 If My memory serves me correctly....( it's been a Year plus since I saw It....) What he did was Took a CV cup, and Welded a Pully to it, then up where spare should have been he set up a York compressor with a pully as well....What he did for clutch to run it was just a idler pully that cammed over a fucrum point to tension up the belt enough to run the compressor..... Put it on the passenger side as it is normally your driver/power side in the trans.....In 2WD mode you can run any gear...... You will have to play with different pully set ups, as his worked, but not as well as it could or should have..... We thought up the Idea before the Rubicon trip while we were sticking the BEAST together......I wanted to do it as well, but didn't have the time...... Have fun, John Quote Link to comment Share on other sites More sharing options...
