attn:moderator's
i found this and thought it would go good in the sticky for offroad.it is a listing of specific vehicle's equipped with 6 lug rims we can use.it is only missing a couple...........
6 x 5 1/2" Make Model Years of Production Chevrolet All thru 1948 Chevrolet & GMC Pickup and Van thru 1970 Chevrolet & GMC K-10, K-1500, 4WD Blazer, And Jimmy 1971-86 Chevrolet Luv Pickup 1972-83 Datsun All Pickups 1967-86 Dodge D-50, Ram 50 Pickup 1979-87 Ford Courier Pickup 1977-84 Mazda Pickup 1972-84 Nissan/Datsun Pickup, Pathfinder 1967-89 Toyota SR5, 4-Runner, Land Crusier, 4WD Hilux 1969-85(some to 1989
I added this to the FAQ Sticky. Thanks.
I'll leave this thread open for a little while and see if anyone can fill in the missing blanks.
Dodge Raider (1988 and maybe 89-91?) is also 6x5.5. In fact, I found one with a set of chrome rims that I am tempted to buy...if I hadn't just bought the Isuzu rims last weekend. Oh, Isuzu's also use the 6x5.5 rims, too (don't know what years, but I think its a large range).
Jeep Wagoneers also run a 6 X 5 1/2
Good info!
However 6x5.5" rims are only half the battle. We need rims with 3.75" or less backspacing to run wider tires.
Regarding the Mazdas... I belive the 4x4's used rims we can use up to around 94-95 (whenever they changed from the B2200 and 2600 to the ranger based 2400-3000-4000)
Good point about the back spacing. I measured the rims more accurately, and the Isuzu rims I have are 3.75" backspace versus the 4.5" stock rims. So I think at least the Isuzu rims are possibilities.
not a big fan of em but they do make those rim shim things...
might have to install longer studs to accomodate some of the more deeper rims/spacer setups
the chevy rims i have are from the early 80's and have the 3.75 backspacing......it seems that whatever rim you are looking at calls for a test fit....regardless of knowledge......every one has different ideas of what is "legal" to run on your rig...
