TheSubaruJunkie Posted September 5, 2003 Share Posted September 5, 2003 Today on the way to work, i noticed my voltmeter was pegged at the red. So I turned on my headlights, put the AC on full and decreased my RPM alittle. It was able to drop the Voltage down to 15 or 16. At a red light, the voltmeter will hold steady at 14, but if I raise the RPM's, it will peg the voltmeter. I suspect my VR is bad. And if it is, how much longer until the alternator goes out? Will a bad VR jepordise my battery? -Brian Link to comment Share on other sites More sharing options...
syphon Posted September 5, 2003 Share Posted September 5, 2003 Definately sounds like the VR is toast. I'd recommend getting a new Alternator ASAP. I got one at Pull A Part for $8.50, works beautifully. On a side note, it's kind of a testament to how solid a Subaru really is. My VR went bad and I still drove it to work and home. a 50 minute commute, both ways, with the needle pegged at 18 volts. When I slapped the new alt. in, there was no lasting damage. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 5, 2003 Share Posted September 5, 2003 Yeah - replace it soon - overvoltage can blow fuses, switches, sensors, and cause fires if wires overheat (although - your fuses are supposed to prevent that). GD Link to comment Share on other sites More sharing options...
NV Zeno Posted September 6, 2003 Share Posted September 6, 2003 Just another item to add to the "shopping list" for Wednesday... Link to comment Share on other sites More sharing options...
archemitis Posted September 6, 2003 Share Posted September 6, 2003 they can get bad enough to effect performance. once i couldnt go over 50mph. and the tach was all over the place, along with all guages. for some reason my regulators always go bad, never the alternator itself. weak link i guess. Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted September 6, 2003 Author Share Posted September 6, 2003 Ok. Good idea Dave, dont let me forget. -Brian Link to comment Share on other sites More sharing options...
edrach Posted September 6, 2003 Share Posted September 6, 2003 Burns out headlamp bulbs too! Link to comment Share on other sites More sharing options...
subieman Posted September 6, 2003 Share Posted September 6, 2003 That sucks brian. Same thing happened to my Hatch last month. Link to comment Share on other sites More sharing options...
Adam N.D.J. Posted September 6, 2003 Share Posted September 6, 2003 Must be about that time for the Soobs. On my way home today in the 3-door, we started it up, and all the idiot lights were on, and the voltage wouldn't go over 9 volts regardless of RPM. Then on the freeway the lights went out, and the voltage went up to 12 and held. So it's bout time for a new alternator. As for overvoltage, it can boil your battery, and that is a really bad thing for the bat. Should be fixed asap. Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted September 6, 2003 Author Share Posted September 6, 2003 If I keep the voltage between 12 and 16 volts will it still harm my electronic stuff? Ive parked the car, and will replace the alt and some wiring later in the week. I am going to wire a new stereo and CB. Anyone have any wiring tips to help protect my car from exploding I also have two 150watt off-road lights i need to wire too. -Brian Link to comment Share on other sites More sharing options...
MilesFox Posted September 6, 2003 Share Posted September 6, 2003 does the alternator have a ground tab on the side? if i recall your ride is an 84? if no tab(which is on 82 and before) the VR is internal in the alt. new alternator! Link to comment Share on other sites More sharing options...
