Phaedras Posted June 7, 2005 Share Posted June 7, 2005 Been wondering about this. I can't seem to get my Loyale SPFI AT above 20-21 mpgs. Now with my configuration which includes performance coil, wires plus new filters, cap and rotor I should at least be able to hit 23-24. In the beginning my tires were 3 of the same brand and 1 of a different brand. Even tire wear, still had a year or two of driving in them. Due to unforseeabel circumstance, I now have 2 balding front tires of the same brand and two different yet decent rear tires of different brands. Could this be affecting my gas mileage enough that with new tires I could easily gain a mpg or two? Quote Link to comment Share on other sites More sharing options...
ballitch Posted June 7, 2005 Share Posted June 7, 2005 depends on the quality of the tire, and if you keep them inflated, rotated and have your car's alignment in good order, plus the way you drive, but for the most part id say its your P.O.S. automatic trhats the biggest problem. ~Josh~ Quote Link to comment Share on other sites More sharing options...
WagonsOnly Posted June 7, 2005 Share Posted June 7, 2005 Inflation is the biggest determinant of mileage as far as tires go. Are you running rich/is the timing set properly? 21mpg seems awfully low even for the slushbox. My mom got between 26-30 (mostly highway) in hers. Quote Link to comment Share on other sites More sharing options...
Phaedras Posted June 7, 2005 Author Share Posted June 7, 2005 Yah, I actually tried running all tires at 35-40 just for kicks to see if by lowering the amount of tire hitting the road I could create less drag. Didn't help, though. It hardly matters if they're at 28 or 40 psi. Timing has been tried at 18 as well as 22 and 24 degrees. No change either, maybe a mpg less at higher timings. Now it's at a solid 22. I don't think I'm running to rich either, at least it doesn't smell like it and my O2 is new. MAF? TPS? Quote Link to comment Share on other sites More sharing options...
Phaedras Posted June 7, 2005 Author Share Posted June 7, 2005 bump. Quote Link to comment Share on other sites More sharing options...
soobmater Posted June 7, 2005 Share Posted June 7, 2005 i kinda have a similiar question, when i get my car back, about how much mpg am i gonna get.tires are 215/75/15's wich calc at 27.7 the rims are 15 inch pug alloys. engine is a ea82. stock exhaust too, but will have replaced shortly. pretty much everything else is stock. a rough estimate would be nice. Quote Link to comment Share on other sites More sharing options...
soobmater Posted June 7, 2005 Share Posted June 7, 2005 by the way it is a 85gl wagon Quote Link to comment Share on other sites More sharing options...
archemitis Posted June 7, 2005 Share Posted June 7, 2005 i kinda have a similiar question, when i get my car back, about how much mpg am i gonna get.tires are 215/75/15's wich calc at 27.7 the rims are 15 inch pug alloys. engine is a ea82. stock exhaust too, but will have replaced shortly. pretty much everything else is stock. a rough estimate would be nice. afraid your mileage will be pretty horrible, compared to a stock one. Quote Link to comment Share on other sites More sharing options...
dragonwingsubaru Posted June 7, 2005 Share Posted June 7, 2005 well i am running 185/70-13 stock size tires at 44psi(max for those) and the timing set somewheres around 14btdc, and just straight mountian driving im getting about 33mpg, ive never even had my sooby on the highway. im gonna have to agree with ballitch and say its prob the auto tranny thats killing your milage, is it a 3 or 4 spd?? Quote Link to comment Share on other sites More sharing options...
Phaedras Posted June 8, 2005 Author Share Posted June 8, 2005 I have a 3AT. See, everyone keeps ragging on my Automatic and Jebus knows that I hate it too, but 20-21 is really off the wall for a car which seems to be in relatively good condition. My plugs are gapper wider, I have a hotter spark and more airflow than stock. So something MUST be off. What sensors contribute to the injection system's calculations, if the tires are not the main culprit? Quote Link to comment Share on other sites More sharing options...
Phaedras Posted June 8, 2005 Author Share Posted June 8, 2005 Bump. Quote Link to comment Share on other sites More sharing options...
cannonball Posted June 8, 2005 Share Posted June 8, 2005 Don't know much about your car, but I replaced the pcv valve in my 00 OBW a couple a months ago and I have consistantly been getting 30-40 miles more per tank of gas. The car has 118,000 on it and the the old valve I took out had old oil in it. Quote Link to comment Share on other sites More sharing options...
