turbo92subaru Posted June 13, 2005 Share Posted June 13, 2005 I have an E test coming up and wanted to know if there were any good ways to pass this thing without putting to much money in to it. Exhaust is new and all of the other general maintenance is kept up well. Any good octane boost out there. I have heard of methynol mixed with some gas. But not to sure about that one. lol. Quote Link to comment Share on other sites More sharing options...
SuBrat84 Posted June 13, 2005 Share Posted June 13, 2005 I haven't tried it.. but supposedly 4 caps of rubbing alcohol for every 5 galllons gas should help you pass. Quote Link to comment Share on other sites More sharing options...
turbo92subaru Posted June 13, 2005 Author Share Posted June 13, 2005 k cool. I haven't tried it either but Im going to. haha. Tell ya how it worked after i get it done. Quote Link to comment Share on other sites More sharing options...
Andyjo Posted June 13, 2005 Share Posted June 13, 2005 Rubbing Alchohol = Isopropal = Dry Gas just to let you know. just dont drink it, you'll die. Quote Link to comment Share on other sites More sharing options...
edrach Posted June 13, 2005 Share Posted June 13, 2005 Your turbo is fuel injected and you should pass emissions without any trouble. You'd be getting a check engine light if the emissions are far enough off to fail. Just make sure your air cleaner is new and not causing you to run too rich and make sure the catalytic converter is good and hot when you arrive at emissions; run it up and down the highway before you go. Quote Link to comment Share on other sites More sharing options...
turbo92subaru Posted June 13, 2005 Author Share Posted June 13, 2005 Ya im hoping it will pass with no problem. But would the alchohol hurt anything, if I use just a little and only once. I know it makes the fuel burn longer which makes it hotter and I ahve a chance of burning up my pistons if I use too much. But what about only this time? Quote Link to comment Share on other sites More sharing options...
forester2002s Posted June 13, 2005 Share Posted June 13, 2005 I used to have a gas-guzzling Dodge V8. To get through the e-test, I used to increase the idle speed as far as I dared. In my case, the V8 would fail on the idle test, and this helped get it passed. The test centre had a max limit on the idle RPM, I think that it was either 1100 or 1500 RPM. One time I was over the limit, the engine was screaming at idle; the testman let me get away with it, but warned me: 'not the next time...' And one other obvious tip: make sure that the engine is good and hot before going in for the test. Quote Link to comment Share on other sites More sharing options...
Andyjo Posted June 13, 2005 Share Posted June 13, 2005 drygas gets rid of water in gas, if you have bad gas, in the winter or something. Thus making it 'purer' and burns cleaner Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted June 14, 2005 Share Posted June 14, 2005 The first gen legacies run pretty clean. You shouldn't have any problems passing. I've heard of guys passing without a cat on. Quote Link to comment Share on other sites More sharing options...
Tiny Clark Posted June 14, 2005 Share Posted June 14, 2005 Make sure the rubbing alcohol is a high percentage rating. Some off the shelf stuff is about 70%, the other part being water. Quote Link to comment Share on other sites More sharing options...
turbo92subaru Posted June 17, 2005 Author Share Posted June 17, 2005 what about ethynol? 99.9% alc. Quote Link to comment Share on other sites More sharing options...
Skip Posted June 18, 2005 Share Posted June 18, 2005 another tip is a fresh oil change if the oil is old and has been tainted with raw gasoline during cold weather starts it can release the gas vapors which will be recycled into the intake manifold via the PCV system I have also heard of people removing the air filter element so the mixture is not made artificially rich but a semi clogged element. The EJ22 is a pretty clean burner as Josh says and if the FI ECU is not tossing it's cookies like Ed refered to, there should be no problems but Every little bit helps Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 18, 2005 Share Posted June 18, 2005 i went through without a cat and failed like a champ, over twice the limit. the CE light being on doesn't necessarily mean much, mine wasn't on when i had my converter off and i didn't pass. if the CE light is on, then you surely shouldn't bother trying to have it tested unless you know exactly why it's on and it's possible effects on the emissions. some states now won't even check your emissions if the CE light is on. like mentoined earlier, a good running subaru should pass with no problems. good spark and fuel and you should be fine. my 200,000 + XT6 passed just fine (after i installed a cat!). make sure the car/exhaust has been driven and nice and hot when you show up. the catalyst in the converter works best when hot. Quote Link to comment Share on other sites More sharing options...
turbo92subaru Posted June 27, 2005 Author Share Posted June 27, 2005 Had my car in for the E test today. Passed with no problems. I was soo happy. 240,000 km, I was pretty worried about what was going to happen with the test. But can never look down at a subie thats for sure. Quote Link to comment Share on other sites More sharing options...
